BANGC 写 Hello BangC! QiuJiang2019-07-11 17:47:30 回复 11 查看 资源共享
别的不说,直接上代码啦
以下是bangc萌新选手码的,可能有一些不够(you)美(bug)丽的地方,望小哥哥小姐姐指教~
Host: "main.cpp"
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #include "cnrt.h"
  4. #include "kernel.h"
  5.
  6. int main() {
  7.   cnrtInit(0);
  8.   cnrtDev_t dev;
  9.   cnrtGetDeviceHandle(&dev, 0);
  10.   cnrtSetCurrentDevice(dev);
  11.   cnrtStream_t pStream;
  12.   cnrtCreateStream(&pStream);
  13.   cnrtDim3_t dim;
  14.   dim.x = 1;
  15.   dim.y = 1;
  16.   dim.z = 1;
  17.
  18.   cnrtFunctionType_t c;
  19.   c = CNRT_FUNC_TYPE_BLOCK;
  20.
  21.   cnrtKernelParamsBuffer_t params;
  22.   cnrtGetKernelParamsBuffer(¶ms);
  23.
  24.   cnrtRet_t ret;
  25.   ret = cnrtInvokeKernel((void *)&kernel, dim, params, c, pStream);
  26.   if (ret != CNRT_RET_SUCCESS) {
  27.     printf("cnrtInvokeKernel FAILED");
  28.     exit(-1);
  29.   }
  30.   ret = cnrtSyncStream(pStream);
  31.   if (ret != CNRT_RET_SUCCESS) {
  32.     printf("cnrtSyncStream FAILED");
  33.     exit(-1);
  34.   }
  35.
  36.   if (CNRT_RET_SUCCESS != cnrtDestroyStream(pStream)) {
  37.     printf("cnrtDestroyStream FAILED!\n");
  38.     exit(-1);
  39.   }
  40.   if (CNRT_RET_SUCCESS != cnrtDestroyKernelParamsBuffer(params)) {
  41.     printf("cnrtDestroyKernelParamsBuffer failed!\n");
  42.     return -1;
  43.   }
  44.   cnrtDestroy();
  45.   return 0;
  46. }
Device: "kernel.mlu"
  1. #include "mlu.h"
  2.
  3. __mlu_entry__ void kernel() {
  4.     __bang_printf("
  5. \n");
  6. }
"kernel.h"
  1. #ifdef __cplusplus
  2. extern "C" {
  3. #endif
  4.   void kernel();
  5. #ifdef __cplusplus
  6. }
  7. #endif
"Makefile"
  1. all:
  2.     cncc -c kernel.mlu -o kernel.o
  3.     g++ -c main.cpp -I/usr/local/neuware/include
  4.     g++ kernel.o main.o -o main -L/usr/local/neuware/lib64 -lcnrt
以上代码文件码好之后,命令行执行:
make
就完成啦!
