从官网拉下cnstream源码后,在进行编译之前需要安装依赖项(依赖项及安装命令具体见 源码目录下的README文档)!在安装
libopencv-dev 过程中,根据系统的设置,可能会出现缺少很多依赖库的问题,导致cmake不通过,无法编译!问题如下:
(作者出现问题的系统是ubuntu16.04)
执行命令如下:
sudo apt-get install libopencv-dev
提示错误:
The following packages have unmet dependencies: libopencv-dev : Depends: libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-ml-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-imgproc-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-objdetect-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-flann-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-legacy-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-contrib-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-ts-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-photo-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-videostab-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-stitching-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-gpu-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-superres-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libopencv-ocl-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libcv-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libhighgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed Depends: libcvaux-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
如图:
解决方法:
这是由于系统的apt镜像源出了问题,应该更换回系统之前的镜像源!换回之后,需要重新进行编译,然后问题解决!
最新帖子
