疑似驱动安装不成功/重启后掉驱动了。辛苦您:终端输入lspci -v -d:220/270 检查驱动是否安装成功。安装驱动后,输入dmesg,并给出dmesg输出截图展开
[ 1169.221048] INFO: [pci_hw_msi_enable][289][CPU 2]: 0xfee0001f [ 1169.221059] INFO: [adjust_dev_param][121][CPU 2]: PCIe DEV_CONTROL_STATUS_REG :0x2930 [ 1169.221061] INFO: [adjust_dev_param][124][CPU 2]: PCIe DMA Capability and Version Register:1 [ 1169.221064] INFO: [adjust_dev_param][131][CPU 2]: PCIe 0x109234 value:3ea40 t:2 [ 1169.221100] INFO: [pci_hw_msi_enable][262][CPU 2]: MSK_ADDR_L:0xfee00078 [ 1169.221102] INFO: [pci_hw_msi_enable][263][CPU 2]: MSK_ADDR_u:0x0 [ 1169.221103] INFO: [pci_hw_msi_enable][264][CPU 2]: MSK_data:0x0 [ 1169.221104] INFO: [pci_hw_msi_enable][289][CPU 2]: 0xfee0001f [ 1169.221136] INFO: [cn_proc_init][2335][CPU 2]: init OK! [ 1169.221138] INFO: [Card0][cn_core_init_idx][3398][CPU 2]: core idx:0 pf_idx:0 vf_idx:0 [ 1169.221141] INFO: [Card0][cn_mcu_init][389][CPU 2]: mcu init [ 1169.221145] INFO: [Card0][mcu_read_basic_info_mlu270][234][CPU 2]: DDR Training Params set by MCU Finish [ 1169.221151] INFO: [Card0][mcu_read_basic_info_mlu270][294][CPU 2]: board serial: 0000122011100200 [ 1169.221154] INFO: [Card0][mcu_read_basic_info_mlu270][340][CPU 2]: board_model_name MLU270-S4 subsystem_id 0x12, board_model 0x3, peak_power 0x46 [ 1169.221156] INFO: [Card0][mcu_read_basic_info_mlu270][341][CPU 2]: board_idx 2 [ 1169.221159] INFO: [Card0][mcu_read_basic_info_mlu270][357][CPU 2]: bus_width 64 ecc_support 1, stack_size 409 [ 1169.221162] INFO: [Card0][mcu_read_basic_info_mlu270][360][CPU 2]: sram_size 1572864, cache_size 1048576, kc_limit 16, ipu_freq 1000, [ 1169.221165] INFO: [Card0][mcu_version_contorl][266][CPU 2]: MCU Ver: v1.1.3, Standard Ver: v1.1.3 [ 1169.221166] INFO: [Card0][mcu_version_contorl][300][CPU 2]: MCU Version Check successfully. [ 1169.221168] INFO: [Card0][cn_mcu_init][412][CPU 2]: MCU Version: v1.1.3 [ 1169.221171] INFO: [Card0][cn_mcu_init][424][CPU 2]: not over temperature poweroff last time [ 1169.221173] INFO: [cn_host_mcu_trans_init][338][CPU 2]: trans host_mcu trans init [ 1169.221175] INFO: [cn_host_mcu_trans_init][350][CPU 2]: trans hbm repair[0x270cabc] not support [ 1169.221176] INFO: [Card0][cn_mcu_init][429][CPU 2]: trans init over [ 1169.221178] INFO: [Card0][cn_mcc_init][87][CPU 2]: mcc init [ 1169.221181] INFO: [Card0][ddr_init_mlu270][255][CPU 2]: ddr: 10FFF [ 1169.221203] INFO: [Card0][smmuv2_init][113][CPU 2]: bar0 reg size = 8000000, mem size = 8000000 [ 1169.221205] INFO: [Card0][smmuv2_init][117][CPU 2]: C20L pcie smmu cau cnt = 45 [ 1169.221226] INFO: [Card0][cn_mm_init][3820][CPU 2]: phy total:0x400000000 [ 1169.221228] INFO: [Card0][cn_mm_init][3825][CPU 2]: vir total:0x10000000000 [ 1169.221231] INFO: [Card0][mempool_init][268][CPU 2]: create pool VA[ffffb6d340000000] -> PA[3affc8000000] : SIZE[8000000] [ 1169.221239] INFO: [Card0][shm_reserved_init][927][CPU 2]: rpc_reserved:alloc host[ffffb6d340000000] <-> dev[8008000000], size = 0x1000 [ 1169.221242] INFO: [Card0][shm_reserved_init][927][CPU 2]: commu_reserved:alloc host[ffffb6d340001000] <-> dev[8008001000], size = 0x10000 [ 1169.221246] INFO: [Card0][shm_reserved_init][927][CPU 2]: kernel_debug_reserved:alloc host[ffffb6d340011000] <-> dev[8008011000], size = 0x100000 [ 1169.221250] INFO: [Card0][shm_reserved_init][927][CPU 2]: pgretire_reserved:alloc host[ffffb6d340111000] <-> dev[8008111000], size = 0x100000 [ 1169.221629] INFO: Domain: cn_dm_init@1993: FLOW: start [ 1169.221634] INFO: Domain: dm_funcid_converter_test@2907: input: 0x0: dm_funcid2vmid[0x10000], dm_vmid2funcid[0x1], dm_funcid2commuid[0x4], dm_commuid2funcid: 0x1 [ 1169.221637] INFO: Domain: dm_funcid_converter_test@2907: input: 0x1: dm_funcid2vmid[0x0], dm_vmid2funcid[0x2], dm_funcid2commuid[0x0], dm_commuid2funcid: 0x2 [ 1169.221639] INFO: Domain: dm_funcid_converter_test@2907: input: 0x2: dm_funcid2vmid[0x1], dm_vmid2funcid[0x3], dm_funcid2commuid[0x1], dm_commuid2funcid: 0x3 [ 1169.221642] INFO: Domain: dm_funcid_converter_test@2907: input: 0x3: dm_funcid2vmid[0x2], dm_vmid2funcid[0x4], dm_funcid2commuid[0x2], dm_commuid2funcid: 0x4 [ 1169.221645] INFO: Domain: dm_funcid_converter_test@2907: input: 0x4: dm_funcid2vmid[0x3], dm_vmid2funcid[0xffffffff], dm_funcid2commuid[0x3], dm_commuid2funcid: 0x0 [ 1169.221649] INFO: Domain: dm_funcid_converter_test@2907: input: 0x5: dm_funcid2vmid[0xffffffff], dm_vmid2funcid[0xffffffff], dm_funcid2commuid[0xffffffff], dm_commuid2funcid: 0xffffffff [ 1169.221652] INFO: Domain: dm_funcid_converter_test@2907: input: 0x10000: dm_funcid2vmid[0xffffffff], dm_vmid2funcid[0x0], dm_funcid2commuid[0xffffffff], dm_commuid2funcid: 0xffffffff [ 1169.221658] INFO: Domain: dm_alloc_and_init_domain_set@1677: domain_set_type<ffff9c4759fb0000> [ 1169.221660] INFO: Domain: dm_alloc_and_init_domains@1655: allocation 1 function is host side. [ 1169.221664] INFO: Domain: dm_domain_initialization@1227: domain(host side) function id<0> magic<0xcabc6870> [ 1169.221670] INFO: Domain: dm_pci_cfg_initialization@618: init pci with data<ffff9c40fcbc4600> bars<5: ffff9c41c4bf9b00> shms<5: ffff9c41c4bf9100> for domain<ffff9c423ce48000> [ 1169.221672] INFO: Domain: dm_domain_initialization@1231: domain[0]: init pcie as pf [ 1169.221676] INFO: Domain: dm_dev_mem_cfg_initialization@585: dev_mem init with data<ffff9c40fcbc4060> for domain[0:ffff9c423ce48000] [ 1169.221679] INFO: Domain: dm_processor_cfg_init@569: init processor<testu>@<ffff9c423ce48060> with data<ffff9c40fcbc4ea0> for domain<ffff9c423ce48000> [ 1169.221683] INFO: Domain: dm_processor_cfg_init@569: init processor<ipu>@<ffff9c423ce480f8> with data<ffff9c40fcbc4b40> for domain<ffff9c423ce48000> [ 1169.221686] INFO: Domain: dm_processor_cfg_init@569: init processor<vpu>@<ffff9c423ce48190> with data<ffff9c40fcbc41e0> for domain<ffff9c423ce48000> [ 1169.221689] INFO: Domain: dm_processor_cfg_init@569: init processor<jpu>@<ffff9c423ce48228> with data<ffff9c40fcbc4720> for domain<ffff9c423ce48000> [ 1169.221691] INFO: Domain: dm_domain_initialization@1265: DONE [ 1169.221693] INFO: Domain: dm_alloc_and_init_domains@1655: allocation 2 function is host side. [ 1169.221697] INFO: Domain: dm_domain_initialization@1227: domain(host side) function id<0> magic<0xcabc6870> [ 1169.221702] INFO: Domain: dm_pci_cfg_initialization@618: init pci with data<ffff9c40fcbc4240> bars<5: ffff9c41c4bf8300> shms<5: ffff9c41c4bf8a00> for domain<ffff9c4b1b10e000> [ 1169.221704] INFO: Domain: dm_domain_initialization@1231: domain[0]: init pcie as pf [ 1169.221707] INFO: Domain: dm_dev_mem_cfg_initialization@585: dev_mem init with data<ffff9c40fcbc4e40> for domain[0:ffff9c4b1b10e000] [ 1169.221710] INFO: Domain: dm_processor_cfg_init@569: init processor<testu>@<ffff9c4b1b10e060> with data<ffff9c40fcbc4480> for domain<ffff9c4b1b10e000> [ 1169.221714] INFO: Domain: dm_processor_cfg_init@569: init processor<ipu>@<ffff9c4b1b10e0f8> with data<ffff9c40fcbc4900> for domain<ffff9c4b1b10e000> [ 1169.221717] INFO: Domain: dm_processor_cfg_init@569: init processor<vpu>@<ffff9c4b1b10e190> with data<ffff9c40fcbc4de0> for domain<ffff9c4b1b10e000> [ 1169.221720] INFO: Domain: dm_processor_cfg_init@569: init processor<jpu>@<ffff9c4b1b10e228> with data<ffff9c40fcbc4a80> for domain<ffff9c4b1b10e000> [ 1169.221721] INFO: Domain: dm_domain_initialization@1265: DONE [ 1169.221724] INFO: Domain: dm_domain_initialization@1227: domain(host side) function id<1> magic<0xcabc6876> [ 1169.221729] INFO: Domain: dm_pci_cfg_initialization@618: init pci with data<ffff9c40fcbc40c0> bars<5: ffff9c41c4bf9600> shms<5: ffff9c41c4bfaf00> for domain<ffff9c4b1b10e4a0> [ 1169.221730] INFO: Domain: dm_domain_initialization@1239: domain[1]: init pcie as vf [ 1169.221733] INFO: Domain: dm_dev_mem_cfg_initialization@585: dev_mem init with data<ffff9c40fcbc4300> for domain[1:ffff9c4b1b10e4a0] [ 1169.221736] INFO: Domain: dm_processor_cfg_init@569: init processor<testu>@<ffff9c4b1b10e500> with data<ffff9c40fcbc4180> for domain<ffff9c4b1b10e4a0> [ 1169.221739] INFO: Domain: dm_processor_cfg_init@569: init processor<ipu>@<ffff9c4b1b10e598> with data<ffff9c40fcbc4360> for domain<ffff9c4b1b10e4a0> [ 1169.221742] INFO: Domain: dm_processor_cfg_init@569: init processor<vpu>@<ffff9c4b1b10e630> with data<ffff9c40fcbc4cc0> for domain<ffff9c4b1b10e4a0> [ 1169.221745] INFO: Domain: dm_processor_cfg_init@569: init processor<jpu>@<ffff9c4b1b10e6c8> with data<ffff9c40fcbc4420> for domain<ffff9c4b1b10e4a0> [ 1169.221747] INFO: Domain: dm_domain_initialization@1265: DONE [ 1169.221749] INFO: Domain: cn_dm_init@2002: domain_set_type<ffff9c4759fb0000> [ 1169.221755] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6870> [ 1169.221759] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[63 ffff9c3fc2f3d800] to dst[63: ffff9c423ce48000]. [ 1169.221763] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c423ce48000> pci<ffff9c3fc2f3d800>; src domain<ffff9c423ce48338> pci<ffff9c3fc2f3db38> [ 1169.221765] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c40fcbc4600> src data<ffff9c431b31ec00> [ 1169.221768] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c41c4bf9100> src shms<ffff9c3c3319b600> [ 1169.221770] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c41c4bf9b00> src bars<ffff9c3c3319af00> [ 1169.221774] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c423ce48000> module<ffff9c3fc2f3d800>; src domain<ffff9c423ce482c0> module<ffff9c3fc2f3dac0> [ 1169.221778] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c423ce48000> module<ffff9c3fc2f3d800>; src domain<ffff9c423ce48060> module<ffff9c3fc2f3d860> [ 1169.221782] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c423ce48000> module<ffff9c3fc2f3d800>; src domain<ffff9c423ce480f8> module<ffff9c3fc2f3d8f8> [ 1169.221785] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c423ce48000> module<ffff9c3fc2f3d800>; src domain<ffff9c423ce48190> module<ffff9c3fc2f3d990>
[ 1169.221788] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c423ce48000> module<ffff9c3fc2f3d800>; src domain<ffff9c423ce48228> module<ffff9c3fc2f3da28> [ 1169.221791] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6870> [ 1169.221795] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[0 ffff9c4b1b094000] to dst[0: ffff9c4b1b10e000]. [ 1169.221799] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c4b1b10e000> pci<ffff9c4b1b094000>; src domain<ffff9c4b1b10e338> pci<ffff9c4b1b094338> [ 1169.221801] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c40fcbc4240> src data<ffff9c412526eae0> [ 1169.221804] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c41c4bf8a00> src shms<ffff9c3c33198d00> [ 1169.221806] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c41c4bf8300> src bars<ffff9c3c3319bb00> [ 1169.221810] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e2c0> module<ffff9c4b1b0942c0> [ 1169.221813] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e060> module<ffff9c4b1b094060> [ 1169.221816] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e0f8> module<ffff9c4b1b0940f8> [ 1169.221819] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e190> module<ffff9c4b1b094190> [ 1169.221822] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e228> module<ffff9c4b1b094228> [ 1169.221823] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6870> [ 1169.221826] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[0 ffff9c4b1b094000] to dst[0: ffff9c4b1b10e000]. [ 1169.221829] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c4b1b10e000> pci<ffff9c4b1b094000>; src domain<ffff9c4b1b10e338> pci<ffff9c4b1b094338> [ 1169.221831] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c40fcbc4240> src data<ffff9c412526eae0> [ 1169.221833] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c41c4bf8a00> src shms<ffff9c3c33198d00> [ 1169.221835] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c41c4bf8300> src bars<ffff9c3c3319bb00> [ 1169.221838] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e2c0> module<ffff9c4b1b0942c0> [ 1169.221841] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e060> module<ffff9c4b1b094060> [ 1169.221844] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e0f8> module<ffff9c4b1b0940f8> [ 1169.221847] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e190> module<ffff9c4b1b094190> [ 1169.221850] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e000> module<ffff9c4b1b094000>; src domain<ffff9c4b1b10e228> module<ffff9c4b1b094228> [ 1169.221855] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6876> [ 1169.221858] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[1 ffff9c4b1b0944a0] to dst[1: ffff9c4b1b10e4a0]. [ 1169.221861] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c4b1b10e4a0> pci<ffff9c4b1b0944a0>; src domain<ffff9c4b1b10e7d8> pci<ffff9c4b1b0947d8> [ 1169.221863] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c40fcbc40c0> src data<ffff9c412526ec00> [ 1169.221866] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c41c4bfaf00> src shms<ffff9c3c33198300> [ 1169.221868] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c41c4bf9600> src bars<ffff9c3c3319b200> [ 1169.221871] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c4b1b10e4a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4b1b10e760> module<ffff9c4b1b094760> [ 1169.221875] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e4a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4b1b10e500> module<ffff9c4b1b094500> [ 1169.221878] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e4a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4b1b10e598> module<ffff9c4b1b094598> [ 1169.221882] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e4a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4b1b10e630> module<ffff9c4b1b094630> [ 1169.221886] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4b1b10e4a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4b1b10e6c8> module<ffff9c4b1b0946c8> [ 1169.221888] INFO: Domain: cn_dm_init@2018: PF only mode: clear VF domain [ 1169.221891] INFO: Domain: cn_dm_init@2042: outbound is not supported in this platform, skip the configuration. [ 1169.221893] INFO: Domain: dm_get_domain_test@2889: Got domain<ffff9c4b1b10e000> in func<PF> [ 1169.221895] INFO: Domain: dm_get_domain_test@2893: Got all the 1 domains. [ 1169.221967] INFO: Domain: cn_dm_init@2075: FLOW: done [ 1169.222339] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel0 buf_sz=0x100000, buf_cnt=1 [ 1169.222750] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel1 buf_sz=0x100000, buf_cnt=1 [ 1169.223118] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel2 buf_sz=0x100000, buf_cnt=1 [ 1169.223490] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel3 buf_sz=0x100000, buf_cnt=1 [ 1169.223859] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel4 buf_sz=0x100000, buf_cnt=1 [ 1169.224225] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel5 buf_sz=0x100000, buf_cnt=1 [ 1169.224609] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel6 buf_sz=0x100000, buf_cnt=1 [ 1169.224982] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel7 buf_sz=0x100000, buf_cnt=1 [ 1169.225311] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel8 buf_sz=0x100000, buf_cnt=1 [ 1169.225650] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel9 buf_sz=0x100000, buf_cnt=1 [ 1169.225986] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel10 buf_sz=0x100000, buf_cnt=1 [ 1169.226310] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel11 buf_sz=0x100000, buf_cnt=1 [ 1169.226660] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel12 buf_sz=0x100000, buf_cnt=1 [ 1169.226987] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel13 buf_sz=0x100000, buf_cnt=1 [ 1169.227314] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel14 buf_sz=0x100000, buf_cnt=1 [ 1169.227642] INFO: [Card0][cn_pci_alloc_dma_buffer][1400][CPU 2]: channel15 buf_sz=0x100000, buf_cnt=1 [ 1169.227648] INFO: [Card0][cn_pci_device_share_mem_init][1540][CPU 2]: alloc host[ffffb6d340211000] <-> dev[8008211000] [ 1169.227650] INFO: [Card0][cn_pci_dma_channel_init][1566][CPU 2]: dma channel init successfully [ 1169.227654] INFO: [Card0][pcie_init][688][CPU 2]: channel0: desc_addr=8008211000 [ 1169.227768] INFO: [Card0][pcie_init][688][CPU 2]: channel1: desc_addr=8008221000 [ 1169.227880] INFO: [Card0][pcie_init][688][CPU 2]: channel2: desc_addr=8008231000 [ 1169.227991] INFO: [Card0][pcie_init][688][CPU 2]: channel3: desc_addr=8008241000 [ 1169.228103] INFO: [Card0][pcie_init][688][CPU 2]: channel4: desc_addr=8008251000 [ 1169.228213] INFO: [Card0][pcie_init][688][CPU 2]: channel5: desc_addr=8008261000 [ 1169.228324] INFO: [Card0][pcie_init][688][CPU 2]: channel6: desc_addr=8008271000 [ 1169.228455] INFO: [Card0][pcie_init][688][CPU 2]: channel7: desc_addr=8008281000 [ 1169.228569] INFO: [Card0][pcie_init][688][CPU 2]: channel8: desc_addr=8008291000 [ 1169.228680] INFO: [Card0][pcie_init][688][CPU 2]: channel9: desc_addr=80082a1000 [ 1169.228791] INFO: [Card0][pcie_init][688][CPU 2]: channel10: desc_addr=80082b1000 [ 1169.228904] INFO: [Card0][pcie_init][688][CPU 2]: channel11: desc_addr=80082c1000 [ 1169.229016] INFO: [Card0][pcie_init][688][CPU 2]: channel12: desc_addr=80082d1000 [ 1169.229127] INFO: [Card0][pcie_init][688][CPU 2]: channel13: desc_addr=80082e1000 [ 1169.229241] INFO: [Card0][pcie_init][688][CPU 2]: channel14: desc_addr=80082f1000 [ 1169.229355] INFO: [Card0][pcie_init][688][CPU 2]: channel15: desc_addr=8008301000 [ 1169.229475] INFO: [Card0][cn_pci_dma_async_init][294][CPU 2]: ASYNC DMA INIT [ 1169.229478] INFO: Domain: dm_register_ops_kernel@2252: daemon is not started. register to PF or the only VF [ 1169.229482] INFO: Domain: dm_register_ops@1097: register module<pci> new_ops<ffff9c41ad676510> with top_priv<ffff9c41ad670018> to domain[PF: ffff9c4b1b10e000] successful [ 1169.229484] INFO: [Card0][cn_pci_init][566][CPU 2]: init end [ 1169.229797] INFO: [Card0][cn_i2c_init][160][CPU 2]: i2c init [ 1169.229800] INFO: [Card0][dw_i2c_init][323][CPU 2]: dw_apb_i2c module init [ 1169.229804] INFO: [Card0][dw_i2c_init][332][CPU 2]: IC_CON reg initialized: 0x63 [ 1169.229812] INFO: [Card0][cn_core_setup_cdev][2520][CPU 2]: cdev 235:0, cambricon_dev0, added [ 1169.229994] INFO: [cn_proc_set_init][2127][CPU 2]: PROC SET. [ 1169.230175] INFO: [Card0][cn_bootm_work][2918][CPU 17]: card 0 boot working! [ 1169.230181] INFO: [Card0][cn_core_bootm][2900][CPU 17]: Card0 State change from CN_EARLYINITED to CN_BRINGUP [ 1169.230184] INFO: [Card0][cn_core_bootm][2902][CPU 17]: current time: 4295838s 4295838936 [ 1169.230186] Card[0] MLU270 boot_prepare() [ 1169.230500] INFO: [cn_pci_set_dma_mask][451][CPU 10]: set pcie dma mask64 ok [ 1169.230506] INFO: Domain: dm_bar_pcie2dm@969: id.device<0x270>, pcie id<0x270cabc> [ 1169.230507] INFO: Domain: dm_bar_pcie2dm@973:
[ 1169.230509] INFO: Domain: cn_dm_host_early_init@1923: FLOW: start [ 1169.230511] INFO: Domain: cn_dm_host_early_init@1933: domain_set_type<ffff9c4625acf080> [ 1169.230515] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 1169.230521] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0x8000000000] pa[0x4108000000], register(base[0x0], size[0x4000]) register total size[0x8000000]), share memory(base[0x0], size[0x8000000]), reserved share memory(base[0x850000], size[0x4000]) [ 1169.230523] INFO: Domain: dm_domain_print_pci@2014: pci->dma->ch: 0xf [ 1169.230526] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0xfffffff0 [ 1169.230529] INFO: Domain: dm_domain_set_print@2130: dump domain_set [ 1169.230531] INFO: Domain: dm_domain_set_print@2131: Upper pointer(core)<0x (null)> [ 1169.230532] INFO: Domain: dm_domain_set_print@2132: daemon_state<undef> [ 1169.230534] INFO: Domain: dm_domain_set_print_domain@2094: domain[OVERALL] magic<0xcabc6870> [ 1169.230536] INFO: Domain: dm_domain_set_print_domain@2096: domain state[0x2: invalid] [ 1169.230539] INFO: Domain: dm_domain_print_pu@2078: processor<testu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230541] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230543] INFO: Domain: dm_domain_print_pu@2078: processor< vpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230545] INFO: Domain: dm_domain_print_pu@2078: processor< jpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230547] INFO: Domain: dm_domain_set_print_domain@2116: domain<ffff9c3fc2f3d800>, dev_mem->domain<ffff9c3fc2f3d800>, dev_mem->data<ffff9c431b31e4e0> [ 1169.230549] INFO: Domain: dm_domain_print_dev_mem@2031: number of zones 0 [ 1169.230550] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 1169.230554] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0x8000000000] pa[0x4108000000], register(base[0x0], size[0x4000]) register total size[0x8000000]), share memory(base[0x0], size[0x8000000]), reserved share memory(base[0x850000], size[0x4000]) [ 1169.230555] INFO: Domain: dm_domain_print_pci@2014: pci->dma->ch: 0xf [ 1169.230557] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0xfffffff0 [ 1169.230559] INFO: Domain: dm_domain_set_print@2142: domain<0>: [ 1169.230560] INFO: Domain: dm_domain_set_print_domain@2094: domain[PF] magic<0xcabc6870> [ 1169.230562] INFO: Domain: dm_domain_set_print_domain@2096: domain state[0x1: undef] [ 1169.230564] INFO: Domain: dm_domain_print_pu@2078: processor<testu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230565] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230567] INFO: Domain: dm_domain_print_pu@2078: processor< vpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230569] INFO: Domain: dm_domain_print_pu@2078: processor< jpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230571] INFO: Domain: dm_domain_set_print_domain@2116: domain<ffff9c4b1b094000>, dev_mem->domain<ffff9c4b1b094000>, dev_mem->data<ffff9c412526e2a0> [ 1169.230572] INFO: Domain: dm_domain_print_dev_mem@2031: number of zones 0 [ 1169.230573] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 1169.230578] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0xffffffffffffffff] pa[0xffffffffffffffff], register(base[0xffffffff], size[0xffffffff]) register total size[0xffffffff]), share memory(base[0xffffffff], size[0xffffffff]), reserved share memory(base[0xffffffff], size[0xffffffff]) [ 1169.230580] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0xffffffff [ 1169.230581] INFO: Domain: dm_domain_set_print@2142: domain<1>: [ 1169.230583] INFO: Domain: dm_domain_set_print_domain@2094: domain[VF0] magic<0xcabc6876> [ 1169.230584] INFO: Domain: dm_domain_set_print_domain@2096: domain state[0x1: undef] [ 1169.230585] INFO: Domain: dm_domain_print_pu@2078: processor<testu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230587] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230588] INFO: Domain: dm_domain_print_pu@2078: processor< vpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230590] INFO: Domain: dm_domain_print_pu@2078: processor< jpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 1169.230592] INFO: Domain: dm_domain_set_print_domain@2116: domain<ffff9c4b1b0944a0>, dev_mem->domain<ffff9c4b1b0944a0>, dev_mem->data<ffff9c412526e720> [ 1169.230593] INFO: Domain: dm_domain_print_dev_mem@2031: number of zones 0 [ 1169.230594] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 1169.230597] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0xffffffffffffffff] pa[0xffffffffffffffff], register(base[0xffffffff], size[0xffffffff]) register total size[0xffffffff]), share memory(base[0xffffffff], size[0xffffffff]), reserved share memory(base[0xffffffff], size[0xffffffff]) [ 1169.230599] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0xffffffff [ 1169.230601] INFO: Domain: dm_print_type_size@2929: struct domain_type: 1184 [ 1169.230602] INFO: Domain: dm_print_type_size@2930: struct processor_data: 88 [ 1169.230603] INFO: Domain: dm_print_type_size@2931: struct dev_mem_data: 88 [ 1169.230604] INFO: Domain: dm_print_type_size@2932: struct pci_data: 88 [ 1169.230605] INFO: Domain: dm_print_type_size@2933: struct pmu_data: 88 [ 1169.230607] INFO: Domain: dm_get_domain_test@2889: Got domain<ffff9c4b1b094000> in func<PF> [ 1169.230609] INFO: Domain: dm_get_domain_test@2889: Got domain<ffff9c4b1b0944a0> in func<VF0> [ 1169.230611] INFO: Domain: dm_get_domain_test@2893: Got all the 2 domains. [ 1169.230611] INFO: Domain: cn_dm_host_early_init@1953: FLOW: done [ 1169.230669] INFO: [c20l_hotreset_gen1_to_gen3][836][CPU 10]: PCIe link speed is 8.0GT/s [ 1169.230671] INFO: [c20l_hotreset_gen1_to_gen3][837][CPU 10]: PCIe link width is x16 [ 1169.230688] Domain API: invalid PF domain [ 1169.230690] INFO: [c20l_pcie_shm_area_init][1078][CPU 10]: get from domain size:8000000 [ 1169.331310] INFO: [pcie_register_bar][264][CPU 10]: bar_type=0, bar_index=2, bar.base=ffffb6d398000000, bar.sz=4000000 [ 1169.331313] INFO: [pcie_register_bar][264][CPU 10]: bar_type=0, bar_index=4, bar.base=ffffb6d3c0000000, bar.sz=4000000 [ 1169.331315] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=0, bar.base=ffffb6d428000000, bar.sz=4000000 [ 1169.331317] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=1, bar.base=ffffb6d430000000, bar.sz=4000000 [ 1169.331319] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=2, bar.base=ffffb6d438000000, bar.sz=4000000 [ 1169.331321] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=3, bar.base=ffffb6d440000000, bar.sz=4000000 [ 1169.331322] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=4, bar.base=ffffb6d448000000, bar.sz=4000000 [ 1169.331324] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=5, bar.base=ffffb6d458000000, bar.sz=4000000 [ 1169.331326] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=6, bar.base=ffffb6d460000000, bar.sz=4000000 [ 1169.331327] INFO: [pcie_register_bar][264][CPU 10]: bar_type=1, bar_index=7, bar.base=ffffb6d468000000, bar.sz=4000000 [ 1169.331333] INFO: [c20l_pcie_dma_pre_init][1130][CPU 10]: Domain[63: 0xffff9c3fc2f3d800] [ 1169.331336] INFO: [c20l_pcie_dma_pre_init][1137][CPU 10]: get from domain mask:0xf [ 1169.331347] INFO: [c20l_outbound_pre_init][1175][CPU 10]: ob_mask:0xffff0000 ob_cnt:16 ob_size:0x80000 ob_total_size:800000 ob_axi_addr:8007000000 [ 1169.331668] cambricon-pci-drv_release 0000:af:00.0: irq 557 for MSI/MSI-X [ 1169.331746] INFO: [pci_hw_msi_enable][262][CPU 10]: MSK_ADDR_L:0xfee00078 [ 1169.331748] INFO: [pci_hw_msi_enable][263][CPU 10]: MSK_ADDR_u:0x0 [ 1169.331749] INFO: [pci_hw_msi_enable][264][CPU 10]: MSK_data:0x0 [ 1169.331751] INFO: [pci_hw_msi_enable][289][CPU 10]: 0xfee0001f [ 1169.331762] INFO: [adjust_dev_param][121][CPU 10]: PCIe DEV_CONTROL_STATUS_REG :0x2930 [ 1169.331764] INFO: [adjust_dev_param][124][CPU 10]: PCIe DMA Capability and Version Register:1 [ 1169.331767] INFO: [adjust_dev_param][131][CPU 10]: PCIe 0x109234 value:3ea40 t:2 [ 1169.331803] INFO: [pci_hw_msi_enable][262][CPU 10]: MSK_ADDR_L:0xfee00078 [ 1169.331805] INFO: [pci_hw_msi_enable][263][CPU 10]: MSK_ADDR_u:0x0 [ 1169.331806] INFO: [pci_hw_msi_enable][264][CPU 10]: MSK_data:0x0 [ 1169.331807] INFO: [pci_hw_msi_enable][289][CPU 10]: 0xfee0001f [ 1169.331840] INFO: [Card1][cn_core_init_idx][3398][CPU 10]: core idx:1 pf_idx:1 vf_idx:0 [ 1169.331843] INFO: [Card1][cn_mcu_init][389][CPU 10]: mcu init [ 1169.331848] INFO: [Card1][mcu_read_basic_info_mlu270][234][CPU 10]: DDR Training Params set by MCU Finish [ 1169.331855] INFO: [Card1][mcu_read_basic_info_mlu270][294][CPU 10]: board serial: 0000122006100700 [ 1169.331858] INFO: [Card1][mcu_read_basic_info_mlu270][340][CPU 10]: board_model_name MLU270-S4 subsystem_id 0x12, board_model 0x3, peak_power 0x46 [ 1169.331860] INFO: [Card1][mcu_read_basic_info_mlu270][341][CPU 10]: board_idx 2 [ 1169.331864] INFO: [Card1][mcu_read_basic_info_mlu270][357][CPU 10]: bus_width 64 ecc_support 1, stack_size 409 [ 1169.331866] INFO: [Card1][mcu_read_basic_info_mlu270][360][CPU 10]: sram_size 1572864, cache_size 1048576, kc_limit 16, ipu_freq 1000, [ 1169.331869] INFO: [Card1][mcu_version_contorl][266][CPU 10]: MCU Ver: v1.1.3, Standard Ver: v1.1.3 [ 1169.331871] INFO: [Card1][mcu_version_contorl][300][CPU 10]: MCU Version Check successfully. [ 1169.331873] INFO: [Card1][cn_mcu_init][412][CPU 10]: MCU Version: v1.1.3
[ 1169.331876] INFO: [Card1][cn_mcu_init][424][CPU 10]: not over temperature poweroff last time [ 1169.331878] INFO: [cn_host_mcu_trans_init][338][CPU 10]: trans host_mcu trans init [ 1169.331880] INFO: [cn_host_mcu_trans_init][350][CPU 10]: trans hbm repair[0x270cabc] not support [ 1169.331881] INFO: [Card1][cn_mcu_init][429][CPU 10]: trans init over [ 1169.331883] INFO: [Card1][cn_mcc_init][87][CPU 10]: mcc init [ 1169.331886] INFO: [Card1][ddr_init_mlu270][255][CPU 10]: ddr: 10FFF [ 1169.331905] INFO: [Card1][smmuv2_init][113][CPU 10]: bar0 reg size = 8000000, mem size = 8000000 [ 1169.331907] INFO: [Card1][smmuv2_init][117][CPU 10]: C20L pcie smmu cau cnt = 45 [ 1169.331928] INFO: [Card1][cn_mm_init][3820][CPU 10]: phy total:0x400000000 [ 1169.331930] INFO: [Card1][cn_mm_init][3825][CPU 10]: vir total:0x10000000000 [ 1169.331933] INFO: [Card1][mempool_init][268][CPU 10]: create pool VA[ffffb6d3b0000000] -> PA[3effc8000000] : SIZE[8000000] [ 1169.331941] INFO: [Card1][shm_reserved_init][927][CPU 10]: rpc_reserved:alloc host[ffffb6d3b0000000] <-> dev[8008000000], size = 0x1000 [ 1169.331945] INFO: [Card1][shm_reserved_init][927][CPU 10]: commu_reserved:alloc host[ffffb6d3b0001000] <-> dev[8008001000], size = 0x10000 [ 1169.331949] INFO: [Card1][shm_reserved_init][927][CPU 10]: kernel_debug_reserved:alloc host[ffffb6d3b0011000] <-> dev[8008011000], size = 0x100000 [ 1169.331953] INFO: [Card1][shm_reserved_init][927][CPU 10]: pgretire_reserved:alloc host[ffffb6d3b0111000] <-> dev[8008111000], size = 0x100000 [ 1169.332143] INFO: Domain: cn_dm_init@1993: FLOW: start [ 1169.332146] INFO: Domain: dm_funcid_converter_test@2907: input: 0x0: dm_funcid2vmid[0x10000], dm_vmid2funcid[0x1], dm_funcid2commuid[0x4], dm_commuid2funcid: 0x1 [ 1169.332148] INFO: Domain: dm_funcid_converter_test@2907: input: 0x1: dm_funcid2vmid[0x0], dm_vmid2funcid[0x2], dm_funcid2commuid[0x0], dm_commuid2funcid: 0x2 [ 1169.332150] INFO: Domain: dm_funcid_converter_test@2907: input: 0x2: dm_funcid2vmid[0x1], dm_vmid2funcid[0x3], dm_funcid2commuid[0x1], dm_commuid2funcid: 0x3 [ 1169.332152] INFO: Domain: dm_funcid_converter_test@2907: input: 0x3: dm_funcid2vmid[0x2], dm_vmid2funcid[0x4], dm_funcid2commuid[0x2], dm_commuid2funcid: 0x4 [ 1169.332154] INFO: Domain: dm_funcid_converter_test@2907: input: 0x4: dm_funcid2vmid[0x3], dm_vmid2funcid[0xffffffff], dm_funcid2commuid[0x3], dm_commuid2funcid: 0x0 [ 1169.332158] INFO: Domain: dm_funcid_converter_test@2907: input: 0x5: dm_funcid2vmid[0xffffffff], dm_vmid2funcid[0xffffffff], dm_funcid2commuid[0xffffffff], dm_commuid2funcid: 0xffffffff [ 1169.332169] INFO: Domain: dm_funcid_converter_test@2907: input: 0x10000: dm_funcid2vmid[0xffffffff], dm_vmid2funcid[0x0], dm_funcid2commuid[0xffffffff], dm_commuid2funcid: 0xffffffff [ 1169.332173] INFO: Domain: dm_alloc_and_init_domain_set@1677: domain_set_type<ffff9c47b877c6c0> [ 1169.332175] INFO: Domain: dm_alloc_and_init_domains@1655: allocation 1 function is host side. [ 1169.332179] INFO: Domain: dm_domain_initialization@1227: domain(host side) function id<0> magic<0xcabc6870> [ 1169.332182] INFO: Domain: dm_pci_cfg_initialization@618: init pci with data<ffff9c485dec6f60> bars<5: ffff9c46baf4d300> shms<5: ffff9c46baf4db00> for domain<ffff9c484462e800> [ 1169.332184] INFO: Domain: dm_domain_initialization@1231: domain[0]: init pcie as pf [ 1169.332186] INFO: Domain: dm_dev_mem_cfg_initialization@585: dev_mem init with data<ffff9c485dec6c00> for domain[0:ffff9c484462e800] [ 1169.332189] INFO: Domain: dm_processor_cfg_init@569: init processor<testu>@<ffff9c484462e860> with data<ffff9c485dec6300> for domain<ffff9c484462e800> [ 1169.332191] INFO: Domain: dm_processor_cfg_init@569: init processor<ipu>@<ffff9c484462e8f8> with data<ffff9c485dec6540> for domain<ffff9c484462e800> [ 1169.332193] INFO: Domain: dm_processor_cfg_init@569: init processor<vpu>@<ffff9c484462e990> with data<ffff9c485dec6780> for domain<ffff9c484462e800> [ 1169.332195] INFO: Domain: dm_processor_cfg_init@569: init processor<jpu>@<ffff9c484462ea28> with data<ffff9c485dec6840> for domain<ffff9c484462e800> [ 1169.332196] INFO: Domain: dm_domain_initialization@1265: DONE [ 1169.332198] INFO: Domain: dm_alloc_and_init_domains@1655: allocation 2 function is host side. [ 1169.332200] INFO: Domain: dm_domain_initialization@1227: domain(host side) function id<0> magic<0xcabc6870> [ 1169.332203] INFO: Domain: dm_pci_cfg_initialization@618: init pci with data<ffff9c485dec6c60> bars<5: ffff9c46baf4df00> shms<5: ffff9c46baf4fc00> for domain<ffff9c4a9fe03000> [ 1169.332204] INFO: Domain: dm_domain_initialization@1231: domain[0]: init pcie as pf [ 1169.332205] INFO: Domain: dm_dev_mem_cfg_initialization@585: dev_mem init with data<ffff9c485dec6660> for domain[0:ffff9c4a9fe03000] [ 1169.332207] INFO: Domain: dm_processor_cfg_init@569: init processor<testu>@<ffff9c4a9fe03060> with data<ffff9c485dec66c0> for domain<ffff9c4a9fe03000> [ 1169.332209] INFO: Domain: dm_processor_cfg_init@569: init processor<ipu>@<ffff9c4a9fe030f8> with data<ffff9c485dec6000> for domain<ffff9c4a9fe03000> [ 1169.332211] INFO: Domain: dm_processor_cfg_init@569: init processor<vpu>@<ffff9c4a9fe03190> with data<ffff9c485dec6960> for domain<ffff9c4a9fe03000> [ 1169.332213] INFO: Domain: dm_processor_cfg_init@569: init processor<jpu>@<ffff9c4a9fe03228> with data<ffff9c485dec65a0> for domain<ffff9c4a9fe03000> [ 1169.332214] INFO: Domain: dm_domain_initialization@1265: DONE [ 1169.332216] INFO: Domain: dm_domain_initialization@1227: domain(host side) function id<1> magic<0xcabc6876> [ 1169.332218] INFO: Domain: dm_pci_cfg_initialization@618: init pci with data<ffff9c485dec6120> bars<5: ffff9c46baf4e000> shms<5: ffff9c46baf4eb00> for domain<ffff9c4a9fe034a0> [ 1169.332219] INFO: Domain: dm_domain_initialization@1239: domain[1]: init pcie as vf [ 1169.332221] INFO: Domain: dm_dev_mem_cfg_initialization@585: dev_mem init with data<ffff9c485dec62a0> for domain[1:ffff9c4a9fe034a0] [ 1169.332223] INFO: Domain: dm_processor_cfg_init@569: init processor<testu>@<ffff9c4a9fe03500> with data<ffff9c485dec6180> for domain<ffff9c4a9fe034a0> [ 1169.332225] INFO: Domain: dm_processor_cfg_init@569: init processor<ipu>@<ffff9c4a9fe03598> with data<ffff9c485dec68a0> for domain<ffff9c4a9fe034a0> [ 1169.332227] INFO: Domain: dm_processor_cfg_init@569: init processor<vpu>@<ffff9c4a9fe03630> with data<ffff9c485dec6600> for domain<ffff9c4a9fe034a0> [ 1169.332234] INFO: Domain: dm_processor_cfg_init@569: init processor<jpu>@<ffff9c4a9fe036c8> with data<ffff9c485dec6900> for domain<ffff9c4a9fe034a0> [ 1169.332235] INFO: Domain: dm_domain_initialization@1265: DONE [ 1169.332237] INFO: Domain: cn_dm_init@2002: domain_set_type<ffff9c47b877c6c0> [ 1169.332240] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6870> [ 1169.332243] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[63 ffff9c3fc2f3d800] to dst[63: ffff9c484462e800]. [ 1169.332245] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c484462e800> pci<ffff9c3fc2f3d800>; src domain<ffff9c484462eb38> pci<ffff9c3fc2f3db38> [ 1169.332247] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c485dec6f60> src data<ffff9c431b31ec00> [ 1169.332248] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c46baf4db00> src shms<ffff9c3c3319b600> [ 1169.332250] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c46baf4d300> src bars<ffff9c3c3319af00> [ 1169.332252] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c484462e800> module<ffff9c3fc2f3d800>; src domain<ffff9c484462eac0> module<ffff9c3fc2f3dac0> [ 1169.332255] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c484462e800> module<ffff9c3fc2f3d800>; src domain<ffff9c484462e860> module<ffff9c3fc2f3d860> [ 1169.332260] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c484462e800> module<ffff9c3fc2f3d800>; src domain<ffff9c484462e8f8> module<ffff9c3fc2f3d8f8> [ 1169.332262] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c484462e800> module<ffff9c3fc2f3d800>; src domain<ffff9c484462e990> module<ffff9c3fc2f3d990> [ 1169.332264] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c484462e800> module<ffff9c3fc2f3d800>; src domain<ffff9c484462ea28> module<ffff9c3fc2f3da28> [ 1169.332265] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6870> [ 1169.332268] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[0 ffff9c4b1b094000] to dst[0: ffff9c4a9fe03000]. [ 1169.332270] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c4a9fe03000> pci<ffff9c4b1b094000>; src domain<ffff9c4a9fe03338> pci<ffff9c4b1b094338> [ 1169.332272] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c485dec6c60> src data<ffff9c412526eae0> [ 1169.332273] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c46baf4fc00> src shms<ffff9c3c33198d00> [ 1169.332275] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c46baf4df00> src bars<ffff9c3c3319bb00> [ 1169.332277] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe032c0> module<ffff9c4b1b0942c0> [ 1169.332279] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe03060> module<ffff9c4b1b094060> [ 1169.332281] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe030f8> module<ffff9c4b1b0940f8> [ 1169.332284] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe03190> module<ffff9c4b1b094190> [ 1169.332286] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe03228> module<ffff9c4b1b094228>
[ 1169.332287] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6870> [ 1169.332289] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[0 ffff9c4b1b094000] to dst[0: ffff9c4a9fe03000]. [ 1169.332291] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c4a9fe03000> pci<ffff9c4b1b094000>; src domain<ffff9c4a9fe03338> pci<ffff9c4b1b094338> [ 1169.332292] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c485dec6c60> src data<ffff9c412526eae0> [ 1169.332294] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c46baf4fc00> src shms<ffff9c3c33198d00> [ 1169.332295] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c46baf4df00> src bars<ffff9c3c3319bb00> [ 1169.332297] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe032c0> module<ffff9c4b1b0942c0> [ 1169.332299] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe03060> module<ffff9c4b1b094060> [ 1169.332301] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe030f8> module<ffff9c4b1b0940f8> [ 1169.332303] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe03190> module<ffff9c4b1b094190> [ 1169.332304] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe03000> module<ffff9c4b1b094000>; src domain<ffff9c4a9fe03228> module<ffff9c4b1b094228> [ 1169.332306] INFO: Domain: dm_domain_dup@1449: domain(host side) magic<0xcabc6876> [ 1169.332308] INFO: Domain: dm_domain_copy_per_module_ops@1407: copy domain ops from src[1 ffff9c4b1b0944a0] to dst[1: ffff9c4a9fe034a0]. [ 1169.332310] INFO: Domain: dm_pci_cfg_dup_data@1291: dst domain<ffff9c4a9fe034a0> pci<ffff9c4b1b0944a0>; src domain<ffff9c4a9fe037d8> pci<ffff9c4b1b0947d8> [ 1169.332312] INFO: Domain: dm_pci_cfg_dup_data@1294: pci dst data<ffff9c485dec6120> src data<ffff9c412526ec00> [ 1169.332313] INFO: Domain: dm_pci_cfg_dup_data@1298: pci dst shms<ffff9c46baf4eb00> src shms<ffff9c3c33198300> [ 1169.332314] INFO: Domain: dm_pci_cfg_dup_data@1309: pci dst bars<ffff9c46baf4e000> src bars<ffff9c3c3319b200> [ 1169.332316] INFO: Domain: dm_dev_mem_cfg_dup_data@96: dst domain<ffff9c4a9fe034a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4a9fe03760> module<ffff9c4b1b094760> [ 1169.332318] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe034a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4a9fe03500> module<ffff9c4b1b094500> [ 1169.332320] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe034a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4a9fe03598> module<ffff9c4b1b094598> [ 1169.332322] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe034a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4a9fe03630> module<ffff9c4b1b094630> [ 1169.332324] INFO: Domain: dm_processor_cfg_dup_data@97: dst domain<ffff9c4a9fe034a0> module<ffff9c4b1b0944a0>; src domain<ffff9c4a9fe036c8> module<ffff9c4b1b0946c8> [ 1169.332326] INFO: Domain: cn_dm_init@2018: PF only mode: clear VF domain [ 1169.332328] INFO: Domain: cn_dm_init@2042: outbound is not supported in this platform, skip the configuration. [ 1169.332331] INFO: Domain: dm_get_domain_test@2889: Got domain<ffff9c4a9fe03000> in func<PF> [ 1169.332332] INFO: Domain: dm_get_domain_test@2893: Got all the 1 domains. [ 1169.332396] INFO: Domain: cn_dm_init@2075: FLOW: done [ 1169.332708] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel0 buf_sz=0x100000, buf_cnt=1 [ 1169.332995] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel1 buf_sz=0x100000, buf_cnt=1 [ 1169.333278] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel2 buf_sz=0x100000, buf_cnt=1 [ 1169.333565] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel3 buf_sz=0x100000, buf_cnt=1 [ 1169.333843] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel4 buf_sz=0x100000, buf_cnt=1 [ 1169.334123] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel5 buf_sz=0x100000, buf_cnt=1 [ 1169.334431] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel6 buf_sz=0x100000, buf_cnt=1 [ 1169.334718] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel7 buf_sz=0x100000, buf_cnt=1 [ 1169.334973] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel8 buf_sz=0x100000, buf_cnt=1 [ 1169.335262] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel9 buf_sz=0x100000, buf_cnt=1 [ 1169.335540] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel10 buf_sz=0x100000, buf_cnt=1 [ 1169.335830] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel11 buf_sz=0x100000, buf_cnt=1 [ 1169.336110] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel12 buf_sz=0x100000, buf_cnt=1 [ 1169.336397] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel13 buf_sz=0x100000, buf_cnt=1 [ 1169.336651] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel14 buf_sz=0x100000, buf_cnt=1 [ 1169.336927] INFO: [Card1][cn_pci_alloc_dma_buffer][1400][CPU 10]: channel15 buf_sz=0x100000, buf_cnt=1 [ 1169.336933] INFO: [Card1][cn_pci_device_share_mem_init][1540][CPU 10]: alloc host[ffffb6d3b0211000] <-> dev[8008211000] [ 1169.336935] INFO: [Card1][cn_pci_dma_channel_init][1566][CPU 10]: dma channel init successfully [ 1169.336938] INFO: [Card1][pcie_init][688][CPU 10]: channel0: desc_addr=8008211000 [ 1169.337049] INFO: [Card1][pcie_init][688][CPU 10]: channel1: desc_addr=8008221000 [ 1169.337164] INFO: [Card1][pcie_init][688][CPU 10]: channel2: desc_addr=8008231000 [ 1169.337268] INFO: [Card1][pcie_init][688][CPU 10]: channel3: desc_addr=8008241000 [ 1169.337371] INFO: [Card1][pcie_init][688][CPU 10]: channel4: desc_addr=8008251000 [ 1169.337475] INFO: [Card1][pcie_init][688][CPU 10]: channel5: desc_addr=8008261000 [ 1169.337581] INFO: [Card1][pcie_init][688][CPU 10]: channel6: desc_addr=8008271000 [ 1169.337688] INFO: [Card1][pcie_init][688][CPU 10]: channel7: desc_addr=8008281000 [ 1169.337794] INFO: [Card1][pcie_init][688][CPU 10]: channel8: desc_addr=8008291000 [ 1169.337900] INFO: [Card1][pcie_init][688][CPU 10]: channel9: desc_addr=80082a1000 [ 1169.338003] INFO: [Card1][pcie_init][688][CPU 10]: channel10: desc_addr=80082b1000 [ 1169.338110] INFO: [Card1][pcie_init][688][CPU 10]: channel11: desc_addr=80082c1000 [ 1169.338222] INFO: [Card1][pcie_init][688][CPU 10]: channel12: desc_addr=80082d1000 [ 1169.338327] INFO: [Card1][pcie_init][688][CPU 10]: channel13: desc_addr=80082e1000 [ 1169.338438] INFO: [Card1][pcie_init][688][CPU 10]: channel14: desc_addr=80082f1000 [ 1169.338547] INFO: [Card1][pcie_init][688][CPU 10]: channel15: desc_addr=8008301000 [ 1169.338659] INFO: [Card1][cn_pci_dma_async_init][294][CPU 10]: ASYNC DMA INIT [ 1169.338661] INFO: Domain: dm_register_ops_kernel@2252: daemon is not started. register to PF or the only VF [ 1169.338666] INFO: Domain: dm_register_ops@1097: register module<pci> new_ops<ffff9c4695746510> with top_priv<ffff9c4695740018> to domain[PF: ffff9c4a9fe03000] successful [ 1169.338667] INFO: [Card1][cn_pci_init][566][CPU 10]: init end [ 1169.338677] INFO: [Card1][cn_i2c_init][160][CPU 10]: i2c init [ 1169.338678] INFO: [Card1][dw_i2c_init][323][CPU 10]: dw_apb_i2c module init [ 1169.338682] INFO: [Card1][dw_i2c_init][332][CPU 10]: IC_CON reg initialized: 0x63 [ 1169.338690] INFO: [Card1][cn_core_setup_cdev][2520][CPU 10]: cdev 235:1, cambricon_dev1, added [ 1169.338833] INFO: [cn_proc_set_init][2127][CPU 10]: PROC SET. [ 1169.338965] INFO: [Card1][cn_bootm_work][2918][CPU 3]: card 1 boot working! [ 1169.338971] INFO: [Card1][cn_core_bootm][2900][CPU 3]: Card1 State change from CN_EARLYINITED to CN_BRINGUP [ 1169.338973] INFO: [Card1][cn_core_bootm][2902][CPU 3]: current time: 4295839s 4295839045 [ 1169.338976] Card[1] MLU270 boot_prepare() [ 1169.509712] firmware_sys.img Version: 4.9.0 [ 1169.509714] firmware_sys.img version differ from cndrv_host version,Drv Version: 4.9.2, firmware_sys.img Version: 4.9.0 [ 1169.509714] Card[0] upload fw failure [ 1169.509716] INFO: [Card0][cn_core_bootm][2900][CPU 17]: Card0 State change from CN_BRINGUP to CN_BOOTERR [ 1169.509717] INFO: [Card0][cn_core_bootm][2902][CPU 17]: current time: 4295838s 4295838936 [ 1169.509718] ERROR: [Card0][cn_bootm_work][2943][CPU 17]: card 0 boot error [ 1169.589224] firmware_sys.img Version: 4.9.0 [ 1169.589225] firmware_sys.img version differ from cndrv_host version,Drv Version: 4.9.2, firmware_sys.img Version: 4.9.0 [ 1169.589225] Card[1] upload fw failure [ 1169.589228] INFO: [Card1][cn_core_bootm][2900][CPU 3]: Card1 State change from CN_BRINGUP to CN_BOOTERR [ 1169.589229] INFO: [Card1][cn_core_bootm][2902][CPU 3]: current time: 4295839s 4295839045 [ 1169.589230] ERROR: [Card1][cn_bootm_work][2943][CPU 3]: card 1 boot error [ 1169.904441] ERROR: [Card1][cn_core_open][277][CPU 31]: open failed, core status is 0x5 [ 1170.913752] ERROR: [Card1][cn_core_open][277][CPU 23]: open failed, core status is 0x5 [ 1171.925174] ERROR: [Card1][cn_core_open][277][CPU 31]: open failed, core status is 0x5 [ 1172.936797] ERROR: [Card1][cn_core_open][277][CPU 32]: open failed, core status is 0x5 [ 1173.947191] ERROR: [Card1][cn_core_open][277][CPU 33]: open failed, core status is 0x5 [ 1174.957874] ERROR: [Card1][cn_core_open][277][CPU 21]: open failed, core status is 0x5 [ 1175.969350] ERROR: [Card1][cn_core_open][277][CPU 24]: open failed, core status is 0x5 [ 1176.980394] ERROR: [Card1][cn_core_open][277][CPU 21]: open failed, core status is 0x5 [ 1177.991326] ERROR: [Card1][cn_core_open][277][CPU 23]: open failed, core status is 0x5 [ 1179.001971] ERROR: [Card1][cn_core_open][277][CPU 26]: open failed, core status is 0x5
我也有相同情况:[代码]
[BEGIN] 2022/8/12 2:35:25 dmesg [ 30.922423] INFO: [pcie_ddr_set_done][850][CPU 13]: DDR Training Params set ...... [ 31.423072] INFO: [pcie_ddr_set_done][850][CPU 13]: DDR Training Params set ...... [ 31.872702] INFO: [Card0][cn_core_bootm][2834][CPU 39]: Card0 ARM Boot cost: 3s 3939 [ 31.872708] INFO: [Card0][cn_core_bootm][2890][CPU 39]: Card0 State change from CN_BOOTING to CN_LATEINIT [ 31.872713] INFO: [Card0][cn_core_bootm][2892][CPU 39]: current time: 4294698s 4294698907 [ 31.872723] INFO: Domain: cn_dm_post_init@2110: FLOW: start [ 31.872726] INFO: Domain: cn_dm_post_init@2111: core<ffff9c4316e59818>, core->domain_set<ffff9c4b18628e40> [ 31.872729] INFO: Domain: cn_dm_post_init@2112: MAKE SURE it is print after register_a_channel_nodb [ 31.872807] [__open_an_endpoint_in_host][160][274] channel domain tx_addr ffffb6d340311000 rx_addr ffffb6d340316000 [ 31.872877] INFO: Domain: cn_dm_post_init@2116: Prepare handshaking [ 31.872882] INFO: Domain: dm_queue_rpc@136: rpc<dm_ping:> [ 31.873032] INFO: Domain: dm_queue_rpc@139: return<5: okok> [ 31.873035] INFO: Domain: dm_rpc@154: rpc<dm_version:> [ 31.873075] INFO: Domain: dm_rpc@160: version: 65536 [ 31.873078] INFO: Domain: cn_dm_handshake@959: version: 0x10000 [ 31.873080] INFO: Domain: cn_dm_post_init@2121: Handshaked [ 31.873083] INFO: Domain: cn_dm_post_init@2138: FLOW: start [ 31.873088] INFO: Domain: cn_dm_post_init@2146: get domain OVERALL[63: ffff9c4316e59000] [ 31.873092] INFO: Domain: dm_rpc_set_domain_pci_cfg@615: outbound is not supported in this platform, skip the configuration. [ 31.873154] INFO: Domain: cn_dm_post_init@2153: caps: 0x0 [ 31.873157] INFO: Domain: cn_dm_post_init@2154: FLOW: done [ 31.873204] [__open_an_endpoint_in_host][160][274] channel commu_cn_mm_krpc tx_addr ffffb6d34031b000 rx_addr ffffb6d340320000 [ 31.873301] [__open_an_endpoint_in_host][160][274] channel commu_cn_mm_free_krpc tx_addr ffffb6d340325000 rx_addr ffffb6d34032a000 [ 31.873360] INFO: [Card0][krpc_client_init][4077][CPU 5]: cn memory krpc client register success! [ 31.873409] [__open_an_endpoint_in_host][160][274] channel log_channel_name tx_addr ffffb6d34032f000 rx_addr ffffb6d340334000 [ 31.873655] INFO: vuart: cn_log_vuart_postinit@504: vuart status:4 [ 31.873708] [__open_an_endpoint_in_host][160][274] channel mnt-commu tx_addr ffffb6d340339000 rx_addr ffffb6d34033e000 [ 31.873767] cn_mnt_krpc register success [ 31.873771] INFO: [Card0][cn_core_late_init][2600][CPU 5]: cn_device_heartbeat init [ 31.873835] INFO: Domain: dm_get_domain_test@2889: Got domain<ffff9c4b1d653000> in func<PF> [ 31.873841] INFO: Domain: dm_get_domain_test@2893: Got all the 1 domains. [ 31.873844] INFO: Domain: cn_dm_init_domain@1548: FLOW: start [ 31.873847] INFO: Domain: cn_dm_init_domain@1556: get domain PF[0: ffff9c4b1d653000] [ 31.873850] INFO: Domain: dm_queue_rpc@136: rpc<dm_management:PFonly> [ 31.873902] INFO: Domain: dm_queue_rpc@139: return<5: okok> [ 31.874579] INFO: Domain: dm_rpc_set_domain_set_daemon_state@196: return<5, okok> [ 31.874582] INFO: Domain: cn_dm_get_cfg@1466: Get domain configuration from device. [ 31.874585] INFO: Domain: dm_rpc_get_domain@835: FLOW: start [ 31.874589] INFO: Domain: dm_rpc_get_buf_processor@647: [ 31.874594] INFO: Domain: dm_rpc@154: rpc<dm_version:> [ 31.874634] INFO: Domain: dm_rpc@160: version: 65536 [ 31.874637] INFO: Domain: dm_rpc_get_buf_processor@653: device version: 65536 [ 31.874639] INFO: Domain: dm_rpc@154: rpc<dm_rpc_hdr_version:> [ 31.874679] INFO: Domain: dm_rpc@160: version: 65536 [ 31.874690] INFO: Domain: dm_rpc_get_buf_processor@661: device header version: 65536 [ 31.874693] INFO: Domain: dm_rpc_get_buf_processor@668: version match: transfer the data before priv [ 31.874696] INFO: Domain: dm_rpc_get_buf_processor@682: pkg.hdr.size<120>, COMMU_RPC_SIZE<128> [ 31.874699] INFO: Domain: dm_rpc_get_buf_processor@683: pkg header size<48> [ 31.874702] INFO: Domain: dm_rpc_get_buf_processor@686: func_id<0> [ 31.874844] INFO: Domain: dm_rpc_get_buf_processor@688: rpc sequence number<9> [ 31.874846] INFO: Domain: dm_rpc_get_buf_processor@690: pkg.hdr.ret<cabc4f4b> [ 31.874848] ERR: Domain: dm_rpc_get_buf_processor@692: rpc ok [ 31.874852] dm_received data: : [ 31.874857] 00: 0x0f 00 00 00 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.874862] 16: 0x0f 00 00 00 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.874869] 32: 0x00 00 00 00 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.874873] 48: 0x00 00 00 00 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.874877] 64: 0x00 00 00 00 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.874879] INFO: Domain: dm_rpc_get_buf_processor@717: ret 0xcabc4f4b [ 31.874885] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 31.874888] INFO: Domain: dm_rpc_get_buf_pci@752: [ 31.874890] INFO: Domain: dm_rpc@154: rpc<dm_version:> [ 31.874931] INFO: Domain: dm_rpc@160: version: 65536 [ 31.874933] INFO: Domain: dm_rpc_get_buf_pci@758: device version: 65536 [ 31.874936] INFO: Domain: dm_rpc@154: rpc<dm_rpc_hdr_version:> [ 31.874976] INFO: Domain: dm_rpc@160: version: 65536 [ 31.874979] INFO: Domain: dm_rpc_get_buf_pci@766: device header version: 65536 [ 31.874981] INFO: Domain: dm_rpc_get_buf_pci@774: rpc package header size<48> expect<60> [ 31.874984] INFO: Domain: dm_rpc_get_buf_pci@775: pkg.hdr.size<108>, COMMU_RPC_SIZE<128> [ 31.874986] INFO: Domain: dm_rpc_get_buf_pci@778: func_id<0> [ 31.874988] dm_rpc sending: [ 31.874992] 00: 0x4b 4f bc ca 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.874996] 16: 0x00 00 00 00 6c 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.875000] 32: 0x00 00 01 00 00 00 00 00; 0x05 00 00 00 00 00 00 00 [ 31.875159] INFO: Domain: dm_rpc_get_buf_pci@781: rpc sequence number<12> [ 31.875161] INFO: Domain: dm_rpc_get_buf_pci@783: pkg.hdr.ret<cabc4f4b> [ 31.875163] ERR: Domain: dm_rpc_get_buf_pci@785: rpc ok [ 31.875166] INFO: Domain: dm_rpc_get_buf_pci@801: rpc package header size<48> expect<60> [ 31.875168] INFO: Domain: dm_rpc_get_buf_pci@802: pkg.hdr.size<108>, COMMU_RPC_SIZE<128> [ 31.875170] INFO: Domain: dm_rpc_get_buf_pci@813: get out bound mask from rpc [ 31.875173] INFO: Domain: dm_rpc_get_buf_pci@820: domain[0: PF] pcie out bound mask: 0x0 [ 31.875175] dm_received data: : [ 31.875179] 00: 0x00 00 00 00 80 00 00 00; 0x00 00 00 08 41 00 00 00 [ 31.875183] 16: 0x00 00 00 10 00 00 00 00; 0x00 40 00 00 00 00 00 08 [ 31.875189] 32: 0x00 00 00 00 00 00 00 08; 0x00 00 00 00 00 00 00 00 [ 31.875195] 48: 0x01 00 00 00 00 00 00 00; 0x00 00 00 00 00 00 00 00 [ 31.875197] INFO: Domain: dm_rpc_get_buf_pci@822: ret 0xcabc4f4b [ 31.875200] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 31.875206] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0xffffffffffffffff] pa[0xffffffffffffffff], register(base[0xffffffff], size[0xffffffff]) register total size[0xffffffff]), share memory(base[0xffffffff], size[0xffffffff]), reserved share memory(base[0xffffffff], size[0xffffffff]) [ 31.875212] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0xffffffff [ 31.875215] INFO: Domain: dm_domain_print_pci@2016: ops<ffff9c431d966510>, init<ffffffffc071fa00>, exit<ffffffffc071f870> [ 31.875218] INFO: Domain: dm_rpc_get_domain@853: FLOW: done<ret: 0> [ 31.875221] INFO: Domain: dm_domain_set_print_domain@2094: domain[PF] magic<0xcabc6870> [ 31.875224] INFO: Domain: dm_domain_set_print_domain@2096: domain state[0x8: defined] [ 31.875227] INFO: Domain: dm_domain_print_pu@2078: processor<testu>: cores[0x0] caps[0x0] mems[0x0] [ 31.875230] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xf] caps[0x0] mems[0xf] [ 31.875234] INFO: Domain: dm_domain_print_pu@2078: processor< vpu>: cores[0x0] caps[0x0] mems[0x0] [ 31.875239] INFO: Domain: dm_domain_print_pu@2078: processor< jpu>: cores[0x0] caps[0x0] mems[0x0] [ 31.875243] INFO: Domain: dm_domain_set_print_domain@2116: domain<ffff9c4b1d653000>, dev_mem->domain<ffff9c4b1d653000>, dev_mem->data<ffff9c4318c148a0> [ 31.875245] INFO: Domain: dm_domain_print_dev_mem@2031: number of zones 0 [ 31.875248] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 31.875253] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0x8000000000] pa[0x4108000000], register(base[0x0], size[0x4000]) register total size[0x8000000]), share memory(base[0x0], size[0x8000000]), reserved share memory(base[0x0], size[0x0]) [ 31.875258] INFO: Domain: dm_domain_print_pci@2014: pci->dma->ch: 0x1 [ 31.875260] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0x1b427cb8 [ 31.875263] INFO: Domain: dm_domain_print_pci@2016: ops<ffff9c431d966510>, init<ffffffffc071fa00>, exit<ffffffffc071f870> [ 31.875266] INFO: Domain: cn_dm_get_cfg@1487: Set domain configuration in host done, output result [ 31.875269] INFO: Domain: dm_init_domain@282: FLOW: init domain<ffff9c4b1d653000> in func <PF> [ 31.875275] INFO: Domain: dm_check_state@1884: current state<defined> could push to <init>. [ 31.875279] INFO: Domain: dm_init_module@2513: pci initing<ffffffffc071fa00> with top_priv<ffff9c431d960018> [ 31.875282] INFO: Domain: dm_init_module@2513: pci init done<0> priv<ffff9c431d960018> [ 31.875284] WARN: Domain: dm_init_module@2513: Warning: mem init empty. exit [ 31.875287] WARN: Domain: dm_init_module@2513: Warning: testu init empty. exit [ 31.875289] WARN: Domain: dm_init_module@2513: Warning: ipu init empty. exit [ 31.875291] WARN: Domain: dm_init_module@2513: Warning: vpu init empty. exit [ 31.875294] WARN: Domain: dm_init_module@2513: Warning: jpu init empty. exit [ 31.875296] INFO: Domain: dm_init_domain@315: FLOW: init domain<ffff9c4b1d653000> in func <PF> done [ 31.875299] INFO: Domain: dm_queue_rpc@136: rpc<domain_init:> [ 31.923719] INFO: [pcie_ddr_set_done][850][CPU 13]: DDR Training Params set ...... [ 32.020435] INFO: Domain: dm_queue_rpc@139: return<5: okok> [ 32.020439] INFO: Domain: cn_dm_init_domain@1588: calling cn_mm_late_init [ 32.020442] INFO: Domain: cn_dm_init_domain@1594: calling cn_mm_late_init done [ 32.020444] INFO: Domain: cn_dm_init_domain@1596: calling cn_sbts_late_init [ 32.020495] [__open_an_endpoint_in_host][160][274] channel sbts_ctrl_channel tx_addr ffffb6d340343000 rx_addr ffffb6d340348000 [ 32.020596] [__open_an_endpoint_in_host][160][274] channel sbts_task_channel tx_addr ffffb6d34034d000 rx_addr ffffb6d340352000 [ 32.020695] [__open_an_endpoint_in_host][160][274] channel sbts_dma_trigger_channel tx_addr ffffb6d340357000 rx_addr ffffb6d34035c000 [ 32.020794] [__open_an_endpoint_in_host][160][274] channel sbts_delay_free_channel tx_addr ffffb6d340361000 rx_addr ffffb6d340366000 [ 32.020891] [__open_an_endpoint_in_host][160][274] channel sbts_idc_channel tx_addr ffffb6d34036b000 rx_addr ffffb6d340370000 [ 32.020988] [__open_an_endpoint_in_host][160][274] channel sbts_core_dump_channel tx_addr ffffb6d340375000 rx_addr ffffb6d34037a000 [ 32.021083] [__open_an_endpoint_in_host][160][274] channel sbts_dbg_channel tx_addr ffffb6d34037f000 rx_addr ffffb6d340384000 [ 32.021202] INFO: [Card0][sbts_shm_init][712][CPU 5]: alloc inbound share mem, shm_mgr->host_vaddr:0xffffb6d340389000, shm_mgr->dev_vaddr:0x8008389000 [ 32.021256] INFO: [Card0][sbts_shm_init][712][CPU 5]: alloc inbound share mem, shm_mgr->host_vaddr:0xffffb6d3403c9000, shm_mgr->dev_vaddr:0x80083c9000 [ 32.022090] INFO: [Card0][cn_queue_init_for_func][1350][CPU 6]: queue init for func finish! [ 32.022367] INFO: [Card0][cn_get_hw_info][1444][CPU 5]: malloc shm size is 640 [ 32.023029] INFO: Domain: cn_dm_init_domain@1602: calling cn_sbts_late_init done [ 32.023031] INFO: Domain: cn_dm_init_domain@1606: Getting IPU core masks: 15 [ 32.023034] INFO: Domain: cn_dm_init_domain@1611: Getting number of cluster number<4> [ 32.023036] INFO: Domain: dm_domain_set_print@2130: dump domain_set [ 32.023039] INFO: Domain: dm_domain_set_print@2131: Upper pointer(core)<0xffff9c4316e59818> [ 32.023041] INFO: Domain: dm_domain_set_print@2132: daemon_state<started> [ 32.023045] INFO: Domain: dm_domain_set_print_domain@2094: domain[OVERALL] magic<0xcabc6870> [ 32.023047] INFO: Domain: dm_domain_set_print_domain@2096: domain state[0x2: invalid] [ 32.023051] INFO: Domain: dm_domain_print_pu@2078: processor<testu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 32.023054] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 32.023057] INFO: Domain: dm_domain_print_pu@2078: processor< vpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 32.023060] INFO: Domain: dm_domain_print_pu@2078: processor< jpu>: cores[0xffffffff] caps[0xffffffff] mems[0xffffffff] [ 32.023063] INFO: Domain: dm_domain_set_print_domain@2116: domain<ffff9c4316e59000>, dev_mem->domain<ffff9c4316e59000>, dev_mem->data<ffff9c4318c14660> [ 32.023066] INFO: Domain: dm_domain_print_dev_mem@2031: number of zones 0 [ 32.023068] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 32.023074] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0x8000000000] pa[0x4108000000], register(base[0x0], size[0x4000]) register total size[0x8000000]), share memory(base[0x0], size[0x8000000]), reserved share memory(base[0x0], size[0x0]) [ 32.023079] INFO: Domain: dm_domain_print_pci@2014: pci->dma->ch: 0xf [ 32.023081] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0x0 [ 32.023084] INFO: Domain: dm_domain_set_print@2142: domain<0>: [ 32.023086] INFO: Domain: dm_domain_set_print_domain@2094: domain[PF] magic<0xcabc6870> [ 32.023089] INFO: Domain: dm_domain_set_print_domain@2096: domain state[0x400: started] [ 32.023092] INFO: Domain: dm_domain_print_pu@2078: processor<testu>: cores[0x0] caps[0x0] mems[0x0] [ 32.023094] INFO: Domain: dm_domain_print_pu@2078: processor< ipu>: cores[0xf] caps[0x0] mems[0xf] [ 32.023097] INFO: Domain: dm_domain_print_pu@2078: processor< vpu>: cores[0x0] caps[0x0] mems[0x0] [ 32.023099] INFO: Domain: dm_domain_print_pu@2078: processor< jpu>: cores[0x0] caps[0x0] mems[0x0] [ 32.023103] INFO: Domain: dm_domain_set_print_domain@2116: domain<ffff9c4b1d653000>, dev_mem->domain<ffff9c4b1d653000>, dev_mem->data<ffff9c4318c148a0> [ 32.023105] INFO: Domain: dm_domain_print_dev_mem@2031: number of zones 0 [ 32.023107] INFO: Domain: dm_domain_print_pci@1971: num_of_bar<5> [ 32.023112] INFO: Domain: dm_domain_print_pci@2011: bar<0>: va[0x8000000000] pa[0x4108000000], register(base[0x0], size[0x4000]) register total size[0x8000000]), share memory(base[0x0], size[0x8000000]), reserved share memory(base[0x0], size[0x0]) [ 32.023116] INFO: Domain: dm_domain_print_pci@2014: pci->dma->ch: 0x1 [ 32.023119] INFO: Domain: dm_domain_print_pci@2015: pci->ob->mask: 0x1b427cb8 [ 32.023121] INFO: Domain: dm_domain_print_pci@2016: ops<ffff9c431d966510>, init<ffffffffc071fa00>, exit<ffffffffc071f870> [ 32.023124] INFO: Domain: cn_dm_init_domain@1613: FLOW: end [ 32.023167] [__open_an_endpoint_in_host][160][274] channel cndev-commu tx_addr ffffb6d340940000 rx_addr ffffb6d340945000 [ 32.023270] [__open_an_endpoint_in_host][160][274] channel monitor-commu tx_addr ffffb6d34094a000 rx_addr ffffb6d34094f000 [ 32.054059] INFO: [Card0][cn_core_late_init][2630][CPU 5]: mig_set:0 [ 32.054103] [__open_an_endpoint_in_host][160][274] channel perf-commu tx_addr ffffb6d340958000 rx_addr ffffb6d34095d000 [ 32.255062] INFO: [Card0][cn_core_late_init][2644][CPU 5]: core late init finish [ 32.255067] INFO: [Card0][cn_core_bootm][2864][CPU 5]: Card0 CardLate Init cost: 0s 383 [ 32.255071] INFO: [Card0][cn_core_bootm][2890][CPU 5]: Card0 State change from CN_LATEINIT to CN_RUNNING [ 32.255074] INFO: [Card0][cn_core_bootm][2892][CPU 5]: current time: 4294699s 4294699290 [ 32.255077] INFO: [Card0][cn_bootm_work][2928][CPU 5]: card 0 boot ok [ 32.424365] INFO: [pcie_ddr_set_done][850][CPU 13]: DDR Training Params set ...... [ 32.925012] INFO: [pcie_ddr_set_done][858][CPU 13]: DDR Training Params set by MCU Finish [ 32.925037] Domain API: invalid PF domain [ 32.925046] INFO: [c20l_pcie_shm_area_init][1078][CPU 0]: get from domain size:8000000 [ 33.025100] INFO: [pcie_register_bar][264][CPU 0]: bar_type=0, bar_index=2, bar.base=ffffb6d398000000, bar.sz=4000000 [ 33.025107] INFO: [pcie_register_bar][264][CPU 0]: bar_type=0, bar_index=4, bar.base=ffffb6d3c0000000, bar.sz=4000000 [ 33.025110] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=0, bar.base=ffffb6d3c8000000, bar.sz=4000000 [ 33.025113] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=1, bar.base=ffffb6d3d0000000, bar.sz=4000000 [ 33.025116] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=2, bar.base=ffffb6d3d8000000, bar.sz=4000000 [ 33.025119] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=3, bar.base=ffffb6d3e0000000, bar.sz=4000000 [ 33.025124] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=4, bar.base=ffffb6d3e8000000, bar.sz=4000000 [ 33.025127] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=5, bar.base=ffffb6d3f0000000, bar.sz=4000000 [ 33.025130] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=6, bar.base=ffffb6d3f8000000, bar.sz=4000000 [ 33.025132] INFO: [pcie_register_bar][264][CPU 0]: bar_type=1, bar_index=7, bar.base=ffffb6d400000000, bar.sz=4000000 [ 33.025138] INFO: [c20l_pcie_dma_pre_init][1130][CPU 0]: Domain[63: 0xffff9c4b1ddf4000]
疑似驱动安装不成功/重启后掉驱动了。辛苦您:终端输入lspci -v -d:220/270 检查驱动是否安装成功。安装驱动后,输入dmesg,并给出dmesg输出截图展开
我也有相同情况:
[root@localhost ~]# lspci -v -d:270 3b:00.0 Processing accelerators: Device cabc:0270 Subsystem: Device cabc:0012 Flags: bus master, fast devsel, latency 0, IRQ 555, NUMA node 0 Memory at 3affc0000000 (64-bit, prefetchable) [size=256M] Memory at 3afff4000000 (64-bit, prefetchable) [size=64M] Memory at 3afff0000000 (64-bit, prefetchable) [size=64M] Capabilities: [80] Power Management version 3 Capabilities: [90] MSI: Enable+ Count=1/32 Maskable+ 64bit+ Capabilities: [b0] MSI-X: Enable- Count=256 Masked- Capabilities: [c0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Alternative Routing-ID Interpretation (ARI) Capabilities: [150] Device Serial Number 00-00-00-00-00-00-00-00 Capabilities: [160] Power Budgeting <?> Capabilities: [1b8] Latency Tolerance Reporting Capabilities: [1c0] #16 Capabilities: [200] Single Root I/O Virtualization (SR-IOV) Capabilities: [274] Transaction Processing Hints Capabilities: [300] #19 Capabilities: [400] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?> Capabilities: [900] L1 PM Substates Kernel driver in use: cambricon-pci-drv_release af:00.0 Processing accelerators: Device cabc:0270 Subsystem: Device cabc:0012 Flags: bus master, fast devsel, latency 0, IRQ 557, NUMA node 1 Memory at 3effc0000000 (64-bit, prefetchable) [size=256M] Memory at 3efff4000000 (64-bit, prefetchable) [size=64M] Memory at 3efff0000000 (64-bit, prefetchable) [size=64M] Capabilities: [80] Power Management version 3 Capabilities: [90] MSI: Enable+ Count=1/32 Maskable+ 64bit+ Capabilities: [b0] MSI-X: Enable- Count=256 Masked- Capabilities: [c0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Alternative Routing-ID Interpretation (ARI) Capabilities: [150] Device Serial Number 00-00-00-00-00-00-00-00 Capabilities: [160] Power Budgeting <?> Capabilities: [1b8] Latency Tolerance Reporting Capabilities: [1c0] #16 Capabilities: [200] Single Root I/O Virtualization (SR-IOV) Capabilities: [274] Transaction Processing Hints Capabilities: [300] #19 Capabilities: [400] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?> Capabilities: [900] L1 PM Substates Kernel driver in use: cambricon-pci-drv_release
demsg打印基本就一个情况:[94196.386194] INFO: [Card30][cn_device_heartbeat][3246][CPU 21]: device is not running, core status is CN_BOOTERR[94196.402562] INFO: [Card15][cn_device_heartbeat][3246][CPU 21]: device is not running, core status is CN_BOOTERR[94196.402586] INFO: [Card31][cn_device_heartbeat][3246][CPU 20]: device is not running, core status is CN_BOOTERR[94196.402662] INFO: [Card20][cn_device_heartbeat][3246][CPU 20]: device is not running, core status is CN_BOOTERR[94196.419572] INFO: [Card23][cn_device_heartbeat][3246][CPU 21]: device is not running, core status is CN_BOOTERR[94196.419677] INFO: [Card13][cn_device_heartbeat][3246][CPU 20]: device is not running, core status is CN_BOOTERR[94197.970373] INFO: [Card28][cn_device_heartbeat][3246][CPU 21]: device is not running, core status is CN_BOOTERRlspci -v -d:220打印,其中一个卡的信息如下:f0:00.0 Processing accelerators: Device cabc:0220 Subsystem: Device cabc:0030 Flags: bus master, fast devsel, latency 0, IRQ 272, NUMA node 7 Memory at 82b2000000 (64-bit, prefetchable) [size=16M] Memory at 82b3000000 (64-bit, prefetchable) [size=4M] Memory at 82b0000000 (64-bit, prefetchable) [size=32M] Capabilities: [80] Power Management version 3 Capabilities: [90] MSI: Enable+ Count=1/32 Maskable+ 64bit+ Capabilities: [b0] MSI-X: Enable- Count=598 Masked- Capabilities: [c0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [150] Device Serial Number 00-00-00-00-00-00-00-00 Capabilities: [160] Power Budgeting > Capabilities: [1b8] Latency Tolerance Reporting Capabilities: [1c0] #16 Capabilities: [274] Transaction Processing Hints Capabilities: [300] #19 Capabilities: [400] Vendor Specific Information: ID=0001 Rev=1 Len=010 > Capabilities: [440] Process Address Space ID (PASID) Capabilities: [5c0] Address Translation Service (ATS) Capabilities: [640] Page Request Interface (PRI) Capabilities: [900] L1 PM Substates Kernel driver in use: cambricon-pci-drv_release展开
demsg打印基本就一个情况:
