[代码]
您好,麻烦提供一下模型转换脚本,以方便我们定位问题。
您好,我们脚本已附上,在设置为270版本的时候:
mfus [array([[ 175, 446.5, 239.75, 549, 0.61816, 0],
[ 384.5, 498, 437, 565.5, 0.58594, 0],
[ 245.75, 501.5, 345.25, 530, 0.31348, 0],
[ -1.0156, 482.75, 51.031, 523, 0.3125, 0]])]
======== convert model finish ! ========
在设置为220时:
mfus [array([], shape=(0, 6), dtype=float64)]
import argparse import pdb import cv2 from utils.datasets import * #from utils.utils import * from utils.general import ( non_max_suppression, scale_coords, xyxy2xywh, strip_optimizer) from models.yolo import Model import torch_mlu import torch_mlu.core.mlu_model as ct import torch_mlu.core.mlu_quantize as mlu_quantize import numpy as np #device = 'cpu' #device = ct.mlu_device() #torch.set_grad_enabled(False) def plot_one_box(x, img, color=None, label=None, line_thickness=None): # Plots one bounding box on image img tl = line_thickness or round(0.002 * (img.shape[0] + img.shape[1]) / 2) + 1 # line/font thickness color = color or [random.randint(0, 255) for _ in range(3)] c1, c2 = (int(x[0]), int(x[1])), (int(x[2]), int(x[3])) cv2.rectangle(img, c1, c2, color, thickness=tl, lineType=cv2.LINE_AA) if label: tf = max(tl - 1, 1) # font thickness t_size = cv2.getTextSize(label, 0, fontScale=tl / 3, thickness=tf)[0] c2 = c1[0] + t_size[0], c1[1] - t_size[1] - 3 cv2.rectangle(img, c1, c2, color, -1, cv2.LINE_AA) # filled cv2.putText(img, label, (c1[0], c1[1] - 2), 0, tl / 3, [225, 255, 255], thickness=tf, lineType=cv2.LINE_AA) def get_boxes(prediction, batch_size=1, img_size=640): """ Returns detections with shape: (x1, y1, x2, y2, object_conf, class_score, class_pred) """ print(prediction[0][76][0][0]) reshape_value = torch.reshape(prediction, (-1, 1)) print(reshape_value) #print('~~~~~~~~~~~') print(reshape_value.size()) #print('batchsize:',batch_size) num_boxes_final = reshape_value[0].item() #print('num_boxes_final: ',num_boxes_final) all_list = [[] for _ in range(batch_size)] print('all_list:',all_list) for i in range(int(num_boxes_final)): batch_idx = int(reshape_value[64 + i * 7 + 0].item()) print('batch_idx:',batch_idx) if batch_idx >= 0 and batch_idx < batch_size: bl = reshape_value[64 + i * 7 + 3].item() print('bl:',bl) br = reshape_value[64 + i * 7 + 4].item() print('br:',br) bt = reshape_value[64 + i * 7 + 5].item() print('bt:',bt) bb = reshape_value[64 + i * 7 + 6].item() print('bb',bb) print(bt-bl) print(bb-br) if bt - bl > 0 and bb -br > 0: all_list[batch_idx].append(bl) all_list[batch_idx].append(br) all_list[batch_idx].append(bt) all_list[batch_idx].append(bb) all_list[batch_idx].append(reshape_value[64 + i * 7 + 2].item()) # all_list[batch_idx].append(reshape_value[64 + i * 7 + 2].item()) all_list[batch_idx].append(reshape_value[64 + i * 7 + 1].item()) output = [np.array(all_list[i]).reshape(-1, 6) for i in range(batch_size)] # outputs = [torch.FloatTensor(all_list[i]).reshape(-1, 6) for i in range(batch_size)] return output class DetectMark(): def __init__(self, opt): # initialize models ModelPath = None self.running_mode = opt.arg self.gen_off = opt.genoff if ModelPath is not None: self.model_path = ModelPath else: if self.running_mode == 'cpu' or self.running_mode == 'quant': #self.model_path = './weights/nozip.pt' self.model_path = './edge_two_yolov5s.pth' else: self.model_path = './yolov5_quant.pth' self.model = Model('./models/yolov5s.yaml') if self.running_mode == 'cpu' or self.running_mode == 'quant': state_dict = torch.load(self.model_path, map_location=torch.device('cpu')) self.model.load_state_dict(state_dict, strict=True) self.model.eval() else: self.device = ct.mlu_device() self.quantized_net = torch_mlu.core.mlu_quantize.quantize_dynamic_mlu(self.model.eval().float()) state_dict = torch.load(self.model_path) self.quantized_net.load_state_dict(state_dict, strict=False) self.quantized_net_mlu = self.quantized_net.to(self.device) #self.names = ['mark', 'top_window', 'tissue_box', 'roof_rack', 'pendant', 'spaer_wheel_rack']#self.model.names if hasattr(self.model, 'names') else self.model.modules.names self.names=['road_sign_defect','tree_shelter','linear_crack','reticular','full_of_crack','wave_embracing_bag','rut','potholes'] def detect_img(self, im0, img_size = 640, conf_thres = 0.25, iou_thres = 0.45): colors = [[random.randint(0, 255) for _ in range(3)] for _ in range(len(self.names))] save_img = True with torch.no_grad(): # Padded resize batch_size = 1 #img = letterbox(im0, new_shape = img_size)[0] img = letterbox(im0, new_shape = img_size,auto=False)[0] # Convert img = img[:, :, ::-1].transpose(2, 0, 1) # BGR to RGB, to 3x320x320 img = np.repeat(img, batch_size, axis=0) img = np.ascontiguousarray(img) #img = torch.from_numpy(img).to('cuda').float() img = torch.from_numpy(img).float() img /= 255.0 # 0 - 255 to 0.0 - 1.0 if img.ndimension() == 3: img = img.unsqueeze(0) if self.running_mode == 'cpu' or self.running_mode == 'quant': if self.running_mode == 'quant': qconfig={'iteration': 1, 'use_avg':False, 'data_scale':1.0, 'firstconv':False, 'per_channel': False} quantized_net = torch_mlu.core.mlu_quantize.quantize_dynamic_mlu(self.model.eval().float(),qconfig_spec=qconfig, dtype='int8', gen_quant=True) quantized_net = quantized_net.eval().float() pred = quantized_net(img, augment=False)[0] torch.save(quantized_net.state_dict(), 'yolov5_quant.pth') else: pred = self.model(img, augment=False)[0] # Apply NMS pred = non_max_suppression(pred, conf_thres, iou_thres) print(pred) for i, det in enumerate(pred): if det is not None and len(det): det[:, :4] = scale_coords(img.shape[2:], det[:, :4], im0.shape).round() for c in det[:, -1].unique(): n = (det[:, -1] == c).sum() for *xyxy, conf, cls in det: if save_img: label = '%s %.2f' % (self.names[int(cls)], conf) plot_one_box(xyxy, im0, label=label, color=colors[int(cls)], line_thickness=1) if save_img: cv2.imwrite('./cpu_result.jpg', im0) elif self.running_mode == 'mlu': device = self.device pred = self.quantized_net_mlu(img.to(device)) pred = pred.to(torch.device('cpu')) print("test---------") print(pred[0].shape) pred = get_boxes(pred) print(pred) for i, det in enumerate(pred): if det is not None and len(det): det[:, :4] = scale_coords(img.shape[2:], torch.Tensor(det[:, :4]), im0.shape).round() for c in torch.Tensor(det[:, -1]).unique(): n = (torch.Tensor(det[:, -1]) == c).sum() for *xyxy, conf, cls in det: if save_img: label = '%s %.2f' % (self.names[int(cls)], conf) plot_one_box(xyxy, im0, label=label, color=colors[int(cls)], line_thickness=3) if save_img: cv2.imwrite('./mlu_result.jpg', im0) elif self.running_mode == 'mfus': device = self.device if self.gen_off: print('generate offline model') ct.save_as_cambricon('edge2_5s_4b_4c') torch.set_grad_enabled(False) batch_size = 4 ct.set_core_number(4) ct.set_core_version('MLU220') example_mlu = torch.randn(batch_size, 3,640,640, dtype=torch.float) trace_input = torch.randn(1, 3, 640, 640,dtype=torch.float) trace_input=trace_input.half() example_mlu = example_mlu.half() trace_input=trace_input.to(ct.mlu_device()) trace_model = torch.jit.trace(self.quantized_net,trace_input, check_trace = False) print(trace_model) if self.gen_off: trace_model(example_mlu.to(device)) ct.save_as_cambricon('') exit(0) else: img = img.half() pred = trace_model(img.to(device)) pred = pred.to(torch.device('cpu')) print(pred) print(pred.size()) pred = get_boxes(pred) print(pred) for i, det in enumerate(pred): if det is not None and len(det): det[:, :4] = scale_coords(img.shape[2:], torch.Tensor(det[:, :4]), im0.shape).round() for c in torch.Tensor(det[:, -1]).unique(): n = (torch.Tensor(det[:, -1]) == c).sum() for *xyxy, conf, cls in det: if save_img: label = '%s %.2f' % (self.names[int(cls)], conf) plot_one_box(xyxy, im0, label=label, color=colors[int(cls)], line_thickness=3) if save_img: cv2.imwrite('./mfus_result.jpg', im0) if __name__ == '__main__': parser = argparse.ArgumentParser() parser.add_argument('--arg', type=str, default='cpu', help=' cpu? mlu? mfus? quant? ') parser.add_argument('--genoff', type=str, default=True, help='true or false') # parser.add_argument('--model-path', type=str, default=None) opt = parser.parse_args() DM = DetectMark(opt) img = cv2.imread('./image.jpg') det_result = DM.detect_img(img) # print(det_result) # start = time.time() # for i in range(1): # det_result = DM.detect_img(img) # end = time.time() # time_mean = (end - start)/1 # print('mean_time:%s'%time_mean)
