mmcv支持pytorch1.13编译的pr还未合入,参考:https://github.com/open-mmlab/mmcv/pull/2979展开
我使用https://github.com/ClowDragon/mmcv.git下的main分支进行编译,仍然无法通过,报错如下:
[186/237] c++ -pthread -B /home/kyxz/miniconda3/envs/torch_mlu/compiler_compat -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/kyxz/miniconda3/envs/torch_mlu/include -fPIC -O2 -isystem /home/kyxz/miniconda3/envs/torch_mlu/include -fPIC -DMMCV_WITH_MLU -I/home/kyxz/mmcv/mmcv/ops/csrc/common -I/home/kyxz/mmcv/mmcv/ops/csrc/common/mlu -I/home/kyxz/mmcv/mlu-ops/bangc-ops -I/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch/include -I/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch/include/torch/csrc/api/include -I/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch/include/TH -I/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch/include/THC -I/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch_mlu/csrc -I/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch_mlu/csrc/api/include/torch_mlu -I/usr/local/neuware/include -I/home/kyxz/miniconda3/envs/torch_mlu/include/python3.10 -c -c /home/kyxz/mmcv/mmcv/ops/csrc/pytorch/masked_conv2d.cpp -o /home/kyxz/mmcv/build/temp.linux-x86_64-cpython-310/mmcv/ops/csrc/pytorch/masked_conv2d.o -std=c++17 -fno-gnu-unique -DTORCH_API_INCLUDE_EXTENSION_H '-DPYBIND11_COMPILER_TYPE="_gcc"' '-DPYBIND11_STDLIB="_libstdcpp"' '-DPYBIND11_BUILD_ABI="_cxxabi1011"' -DTORCH_EXTENSION_NAME=_ext -D_GLIBCXX_USE_CXX11_ABI=0
ninja: build stopped: subcommand failed.
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch/utils/cpp_extension.py", line 1900, in _run_ninja_build
subprocess.run(
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['ninja', '-v', '-j', '4']' returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "/home/kyxz/mmcv/setup.py", line 450, in <module>
setup(
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/__init__.py", line 107, in setup
return distutils.core.setup(**attrs)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/dist.py", line 1234, in run_command
super().run_command(command)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/install.py", line 80, in run
self.do_egg_install()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/install.py", line 129, in do_egg_install
self.run_command('bdist_egg')
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/bdist_egg.py", line 164, in run
cmd = self.call_command('install_lib', warn_dir=0)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/bdist_egg.py", line 150, in call_command
self.run_command(cmdname)
cmd_obj.run()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/install_lib.py", line 11, in run
self.build()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/command/install_lib.py", line 111, in build
self.run_command('build_ext')
cmd_obj.run()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 84, in run
_build_ext.run(self)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
self.build_extensions()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch_mlu/utils/cpp_extension.py", line 566, in build_extensions
build_ext.build_extensions(self)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 467, in build_extensions
self._build_extensions_serial()
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 493, in _build_extensions_serial
self.build_extension(ext)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 246, in build_extension
_build_ext.build_extension(self, ext)
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 548, in build_extension
objects = self.compiler.compile(
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch_mlu/utils/cpp_extension.py", line 546, in unix_wrap_ninja_compile
_write_ninja_file_and_compile_objects(
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch_mlu/utils/cpp_extension.py", line 146, in _write_ninja_file_and_compile_objects
torch.utils.cpp_extension._run_ninja_build(
File "/home/kyxz/miniconda3/envs/torch_mlu/lib/python3.10/site-packages/torch/utils/cpp_extension.py", line 1916, in _run_ninja_build
raise RuntimeError(message) from e
RuntimeError: Error compiling objects for extension
似乎是中间的某个算子编译未成功,原因是什么呢
