/usr/bin/gcc
~/cnrt/build ~/cnrt/
-- Build cambricon release test cases.
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- NEUWARE_HOME=/usr/local/neuware/
-- cncc have been found.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/b212/cnrt/build
[ 14%] Building CNCC CMakeFiles/bang_test.dir/tests/bang_test_generated_bang.mlu.o
Scanning dependencies of target module_test
[ 28%] Building C CMakeFiles/module_test.dir/tests/offline.c.o
[ 42%] Building C CMakeFiles/module_test.dir/tests/parallel.c.o
[ 57%] Building C CMakeFiles/module_test.dir/tests/all_test.c.o
[ 71%] Building C CMakeFiles/module_test.dir/tests/serial.c.o
CMake Error at bang_test_generated_bang.mlu.o.cmake:167 (message):
Error generating file
/home/b212/cnrt/build/CMakeFiles/bang_test.dir/tests/./bang_test_generated_bang.mlu.o
CMakeFiles/bang_test.dir/build.make:63: recipe for target 'CMakeFiles/bang_test.dir/tests/bang_test_generated_bang.mlu.o' failed
make[2]: *** [CMakeFiles/bang_test.dir/tests/bang_test_generated_bang.mlu.o] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/bang_test.dir/all' failed
make[1]: *** [CMakeFiles/bang_test.dir/all] Error 2
make[1]: *** 正在等待未完成的任务....
[ 85%] ing C executable module_test
[ 85%] Built target module_test
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
