Job is Running
Job is Running
Job is Running
Job is Running
Job is Succeeded
------------------------------- INFO --------------------------------
| dataset path:
| /workspace/volume/private/00_Yolov3_example/result/data/coco
| Online:
| online model path:
| /workspace/volume/private/00_Yolov3_example/result/model/online/yolov3.pth,
| /workspace/volume/private/00_Yolov3_example/result/model/online/yolov3_int8.pth
| performance test code position:
| /workspace/volume/private/00_Yolov3_example/result/online/yolov3/test.py
| Offline:
| offline model path:
| /workspace/volume/private/00_Yolov3_example/result/model/offline/yolov3.cambricon
| /workspace/volume/private/00_Yolov3_example/result/offline/yolov3/yolov3_offline_multicore.cpp.
------------------------------- RUN ---------------------------------
Running online.
/workspace/volume/private/00_Yolov3_example/online/yolov3 /
CNML: 7.10.2 0a592c0
/workspace/volume/private/sdk/venv/pytorch/lib/python3.7/site-packages/torch/nn/_reduction.py:43: UserWarning: size_average and reduce args will be deprecated, please use reduction='mean' instead.
warnings.warn(warning.format(ret))
CNRT: 4.10.1 a884a9a
File "test.py", line 185, in <module>
nms_thres=0.5)
File "/workspace/volume/private/sdk/venv/pytorch/lib/python3.7/site-packages/torchvision/models/quantization/ _detection/yolov3/models.py", line 41, in yolov3
state_dict = torch.load(quantized_path)
File "/workspace/volume/private/sdk/venv/pytorch/lib/python3.7/site-packages/torch/serialization.py", line 500, in load
f = open(f, 'rb')
FileNotFoundError: [Errno 2] No such file or directory: '../../model/online/yolov3_int8.pth'
Running offline.
/workspace/volume/private/00_Yolov3_example/offline/yolov3 /
nms_thres=0.5)
f = open(f, 'rb')
running yolov3 offline multiple core ...
batch_size: 16, core_number: 16, channel_order: 0
running offline test...
run_cmd: /workspace/volume/private/00_Yolov3_example/offline/yolov3/../build/yolov3/src/yolov3_offline_multicore -offlinemodel /workspace/volume/private/00_Yolov3_example/offline/yolov3/../../model/offline/yolov3.cambricon -images /workspace/volume/private/00_Yolov3_example/offline/yolov3/data/file_list_performance -labels /workspace/volume/private/00_Yolov3_example/offline/yolov3/label_map_coco.txt -outputdir /home/tmp -dump 1 -simple_compile 1 -dataset_path /workspace/dataset/public/zhumeng-dataset/coco_2014/ -perf_mode 1 -perf_mode_img_num 496 -input_format 0 &>> /workspace/volume/private/00_Yolov3_example/offline/yolov3/yolov3_multicore_thread.log
check_cmd: python /workspace/volume/private/00_Yolov3_example/offline/yolov3/../ s/meanAP_COCO.py --file_list /workspace/volume/private/00_Yolov3_example/offline/yolov3/data/file_list_performance --result_dir /home/tmp --ann_dir /workspace/dataset/public/zhumeng-dataset/coco_2014/ --data_type val2014 &>> /workspace/volume/private/00_Yolov3_example/offline/yolov3/yolov3_multicore_thread.log
run_offline_performance.sh: line 44: /workspace/volume/private/00_Yolov3_example/offline/yolov3/../build/yolov3/src/yolov3_offline_multicore: No such file or directory
(pytorch) root@notebook-notebook-zhumeng-1rgyu2t-notebook-0:/workspace/volume/private/submit_job#
