detr转离线模型报错 Ashpool2024-04-22 20:11:58 回复 查看 技术答疑 使用求助 社区交流
detr转离线模型报错
【寒武纪硬件产品型号】必填*:
例如:MLU220
必填项,例如:MLU220
【使用操作系统】必填*:
例如:ubuntu 16.04
【当前已做了哪些信息确认】选填:
基于cpu运行下模型能成功trace,但当tensor和model放到mlu上报错
【出错代码链接】选填:
    if args.cfg == 'qua':
        qconfig={'use_avg':False, 'data_scale':1.0, 'firstconv':False, 'per_channel': False}
        quantized_net = mlu_quantize.quantize_dynamic_mlu(model,qconfig_spec=qconfig, dtype='int8', gen_quant=True)
    elif args.cfg == 'mlu':
        if args.fake_device:
            ct.set_device(-1)
            ct.set_core_version('MLU220')
        model.to(torch.device('cpu'))
        quantized_net = torch_mlu.core.mlu_quantize.quantize_dynamic_mlu(model)
        state_dict = torch.load("./detr_int8.pt")
        quantized_net.load_state_dict(state_dict, strict=False)
        quantized_net.eval()
        quantized_net.to(ct.mlu_device())
        # quantized_net.to(torch.device("cpu"))
        if args.jit:
            print("### jit")
            ct.save_as_cambricon('detr_int8_1_4')
            torch.set_grad_enabled(False)
            ct.set_core_number(4)
            trace_input = torch.randn(1, 3, 640, 640, dtype=torch.float)
            input_mlu_data = trace_input.to(ct.mlu_device())
            # input_mlu_data = trace_input.to(torch.device("cpu"))
            quantized_net = torch.jit.trace(quantized_net, input_mlu_data, check_trace = False)
            outputs_class,outputs_coord = quantized_net(trace_input)
            # quantized_net = torch.jit. (quantized_net)
            ct.save_as_cambricon('')
