背景: MLU220 SOM 板无法从网络加载,选择从 SD 卡加载,烧录失败,提示下面日志中的红色信息,如何解决?
按照《寒武纪SOM%20SDK使用及开发指南_v1.7.0.pdf》中 第 3.2.2 SD 加载 执行操作
日志输出
CAMBR-C20E# C20E ROM: v1.0(release):ac35090
C20E ROM: Built : 20:20:53, Jun 11 2019
Norflash id: 0x709d
C20E ROM boot done.
C20E PREBOOT: Built : 16:49:16, Jun 21 2021
C20E PREBOOT: v120
Norflash id: 0x709d
No config.bin exists
Read Serial Number From NorFlash
Board Serial Number: 362103300418
pcie link up error, ret 2
ddr ok loop 0
Going to boot the atf bl1
C20E preboot done.
NOTICE: Booting Trusted Firmware
NOTICE: BL1: v1.5(release):4.9.5
NOTICE: BL1: Built : 16:49:15, Jun 21 2021
NOTICE: Norflash id: 0x709d
NOTICE: BL1: Booting BL2
NOTICE: BL2: v1.5(release):4.9.5
NOTICE: BL2: Built : 16:49:15, Jun 21 2021
NOTICE: BL1: Booting BL31
NOTICE: BL31: v1.5(release):4.9.5
NOTICE: BL31: Built : 16:49:15, Jun 21 2021
U-Boot 2017.07-cambricon4.9.5 (Jun 21 2021 - 16:49:11 +0800), Build: jenkins-DRIVER-release_mlu220edge_driver_master_daily_pipeline-911
CPU : Cambricon Technologies C20E
DRAM: 1 GiB
MMC: sdhci@8000040000: 0, sdhci@8000044000: 1, sdhci@8000048000: 2
In: serial
Out: serial
Err: serial
Card did not respond to voltage select!
** Bad device mmc 2 **
## Warning: Input data exceeds 1048576 bytes - truncated
## Info: input data size = 1048578 = 0x100002
try to get uenv_extra.txt from emmc...
119 bytes read in 7 ms (16.6 KiB/s)
## Info: input data size = 120 = 0x78
Net: eth0: ethernet@8000054000
Hit any key to stop autoboot: 0
CAMBR-C20E# env default -a
## Resetting to default environment
CAMBR-C20E# setenv force_update force_update=SD
CAMBR-C20E# run set_force_update
force_update=SD
## Executing script at 1008000000
Wrong image format for "source" command
## Error: "recovery_boot" not defined
