mlu370-s4 cnrtQueueSync 超时 已解决 lixiang112023-02-17 18:37:52 回复 6 查看 技术答疑 使用求助 经验交流
我使用magicmind_runtime 进行离线模型推理,出现了CN_INVOKE_ERROR_EXECUTED_TIMEOUT问题?请问是驱动问题吗?还是我的代码有问题,请求帮助,谢谢。
代码比较简单,主体逻辑是加载一个restnet50的模型,模型从cnstream代码示例中下载,然后在板卡上运行,没有进行前后处理。
(1)代码如下:
int main(int argc, char *argv[])
    std::string model_name = "/data/model/resnet50_v0.13.0_4b_rgb_uint8.magicmind";
    std::vector<magicmind::IRTTensor *> input_tensors_;
    std::vector<magicmind::IRTTensor *> output_tensors_;
    std::vector<void *> input_host_ptrs_;
    std::vector<void *> output_host_ptrs_;
    cnrtSetDevice(0);
    magicmind::IModel *model = magicmind::CreateIModel();
    model->DeserializeFromFile(model_name.c_str());
        ///////////////////Print info below//////////////////////
        size_t size = 0;
        model->GetSerializedModelSize(&size);
        std::cout << "Create IModel done." << std::endl;
        std::cout << "Name: " << model_name << " Size: " << size << std::endl;
        std::cout << "Input num: " << model->GetInputNum() << std::endl;
        std::cout << "Input info:[ " << std::endl;
        auto names = model->GetInputNames();
        // CHECK_EQ(names.size(), in_dims_.size());
        auto dims = model->GetInputDimensions();
        auto types = model->GetInputDataTypes();
        for (uint32_t i = 0; i < names.size(); ++i)
            std::cout << names[i] << ": " << dims[i] << ", " << magicmind::TypeEnumToString(types[i]) << std::endl;
        std::cout << "]" << std::endl;
        std::cout << "Output info:[ " << std::endl;
        names = model->GetOutputNames();
        dims = model->GetOutputDimensions();
        types = model->GetOutputDataTypes();
    magicmind::IEngine *engine = model->CreateIEngine();
    magicmind::IContext *context_ = engine->CreateIContext();
    context_->CreateInputTensors(&input_tensors_);
    context_->CreateOutputTensors(&output_tensors_);
    auto input_dim_vec = model->GetInputDimension(0).GetDims();
    if (input_dim_vec[0] == -1)
        input_dim_vec[0] = 4;
    magicmind::Dims input_dims = magicmind::Dims(input_dim_vec);
    for (uint32_t i = 0; i < input_tensors_.size(); ++i)
        input_tensors_[i]->SetDimensions(input_dims);
        auto input_size = input_tensors_[i]->GetSize();
        std::cout << "input_tensors_[i]->GetSize():" << input_size << std::endl;
        void *input_ptr = nullptr;
        cnrtHostMalloc(&input_ptr, input_size);
        input_host_ptrs_.push_back(input_ptr);
        // Some network has param as input, Host address will speed them up.
        if ((input_tensors_[i]->GetMemoryLocation() == magicmind::TensorLocation::kMLU) ||
            (input_tensors_[i]->GetMemoryLocation() == magicmind::TensorLocation::kRemoteMLU))
            input_tensors_[i]->SetData(MallocMLUAddr(input_size));
            Memcpy(input_tensors_[i]->GetMutableData(), input_ptr, input_size, true);
            std::cout << "copy data host2device size=" << input_size << std::endl;
        else
            input_tensors_[i]->SetData(input_ptr);
    magicmind::Status isOk = context_->InferOutputShape(input_tensors_, output_tensors_);
    if (magicmind::Status::OK() == isOk)
        for (uint32_t i = 0; i < model->GetOutputNum(); ++i)
            void *out_ptr = nullptr;
            auto output_size = output_tensors_[i]->GetSize();
            cnrtHostMalloc(&out_ptr, output_size);
            std::cout << "output_tensors_[i]->GetSize():" << output_size << std::endl;
            magicmind::Status isOk = output_tensors_[i]->SetData(out_ptr);
            if (isOk != magicmind::Status::OK())
                std::cout << "SetData message=" << isOk.error_message() << std::endl;
            output_host_ptrs_.push_back(out_ptr);
    cnrtQueue_t queue_ = nullptr;
    cnrtQueueCreate(&queue_);
    isOk = context_->Enqueue(input_tensors_, output_tensors_, queue_);
        std::cout << "Enqueue message=" << isOk.error_message() << std::endl;
    cnrtQueueSync(queue_);
#if 0
    for (uint32_t i = 0; i < output_tensors_.size(); ++i)
        auto size = output_tensors_[i]->GetSize();
        // fill in input data
        Memcpy(output_host_ptrs_[i], output_tensors_[i]->GetMutableData(), size, false);
#endif
    getchar();
    return 0;
(2)运行结果如下:
(3)驱动和软件信息如下:
(4)模型和代码见附件,其去掉后缀.txt
CMakeLists.txt
sample_runtime.cpp.txt
resnet50_v0.13.0_4b_rgb_uint8.magicmind.txt
core_1676658283_pid_49159_mluid_0_queue_670.cndump.txt
