【寒武纪硬件产品型号】MLU370
【MagicMind版本号】:1.0.1
执行命令:./pytorch_build --pytorch_pt ./yolov5_model/yolov5s.pt --dynamic_shape false (pt来自于https://github.com/ultralytics/yolov5)
【出错信息】
2023-09-18 05:10:53.096760: INFO: /usr/local/neuware/samples/magicmind/mm_build/main.cc:13]
==================== Parameter Information
--precision<Str> :
--calibration<Bool> : false
--rpc_server<Str> :
--calibration_algo<Str> : linear
--file_list<Vec<Str>> :
--calibration_data_path<Str> :
--random_calib_range<Vec<Float>>:
--batch_size<Vec<Int>> :
--input_dims<Vec<Vec<Int>>> :
--input_layout<Vec<Str>> :
--input_dtypes<Vec<Str>> :
--dynamic_shape<Bool> : false
--vars<Vec<Vec<Float>>> :
--means<Vec<Vec<Float>>> :
--output_layout<Vec<Str>> :
--output_dtypes<Vec<Str>> :
--mlu_arch<Vec<Str>> :
--plugin<Vec<Str>> :
--magicmind_model<Str> : ./model
--build_config<Str> :
--toolchain_path<Str> : /usr/local/gcc-linaro-6.2.1-2016.11-x86_64_aarch64-linux-gnu/
--rgb2bgr<Bool> : false
--cluster_num<Vec<Vec<Int>>> :
--pytorch_pt<Str> : ./yolov5s.pt
--pt_input_dtypes<Vec<Str>> : FLOAT
MagicMind: 268435472
2023-09-18 05:10:53.101732: ERROR: magicmind/translation/pytorch/module_loader.cc:77] PyTorch loads the model failed due to: [enforce fail at inline_container.cc:209] . file not found: archive/constants.pkl
2023-09-18 05:10:53.101781: ERROR: magicmind/cc/implement/interface_parser_impl.cc:66] Invalid argument: Your input model is not suppported by pytorch.
2023-09-18 05:10:53.101801: ERROR: /usr/local/neuware/samples/magicmind/mm_build/parser.cc:23] Invalid argument: Your input model is not suppported by pytorch.
Aborted (core dumped)
