请教如何使用异步传输 已完结 hxf02232021-06-21 23:10:52 回复 2 查看 使用求助
请教如何使用异步传输
__mlu_func__ void biliner_block(float* ptrOut, float* ptrIn,
    int inWidth, int inHeight, int outWidth, int outHeight, int idX, int idY, int numX) {
    __nram__ float temp_px[BLOCK_SIZE], temp_py[BLOCK_SIZE], temp_result[2][BLOCK_SIZE];
    __nram__ float src_line_buff1[2][BLOCK_SIZE], src_line_buff2[2][BLOCK_SIZE];
    __nram__ int /*temp_x[BLOCK_SIZE],*/ temp_y[BLOCK_SIZE];
    bang::pipeline pipe(0);
    int start_x = idX, start_y = BLOCK_SIZE * idY;
    float factor_y = (inHeight - 1.0f) / (outHeight - 1.0f);    // factor of y axis
    float factor_x = (inWidth - 1.0f) / (outWidth - 1.0f);      // factor of x axis
        printf("taskId: %d. (%d %d) %d\n", taskId, idX, idY, numX);
        return;
    if (start_x >= outWidth || start_y >= outHeight) { return; }
    int end_x = ((start_x+numX) < outWidth) ? (start_x+numX) : outWidth;
    int end_y = ((start_y+BLOCK_SIZE) < outHeight) ? (start_y+BLOCK_SIZE) : outHeight;
    int end_x2 = (end_x == outWidth) ? (end_x-1) : end_x;
    int end_y2 = (end_y == outHeight) ? (end_y-1) : end_y;
    for (int idy = 0; idy < (end_y-start_y); idy++) {
        temp_py[idy] = (idy+start_y) * factor_y;
        temp_y[idy] = (int)(temp_py[idy]);
    for (int idx = 0; idx < (end_x-start_x); idx++) {
        temp_px[idx] = (idx+start_x) * factor_x;
        //temp_x[idx] = (int)(temp_px[idx]);
    int fn_buff_id = 0;
    bang::memcpy_async(pipe, src_line_buff1[fn_buff_id], ptrIn, inHeight*sizeof(float), GDRAM2NRAM);
    bang::memcpy_async(pipe, src_line_buff2[fn_buff_id], ptrIn+inHeight, inHeight*sizeof(float), GDRAM2NRAM);
    for (int idx = 0; idx < (end_x2-start_x); idx++) {
        pipe.wait_copy_dram_to_nram();
        int src_idx = (int)(temp_px[idx]);
        int async_buff_id = (fn_buff_id+1) % 2;
        if ( idx < (end_x2-start_x-1) ) {
            bang::memcpy_async(pipe, src_line_buff1[async_buff_id], ptrIn+src_idx*inHeight, inHeight*sizeof(float), GDRAM2NRAM);
            bang::memcpy_async(pipe, src_line_buff2[async_buff_id], ptrIn+(src_idx+1)*inHeight, inHeight*sizeof(float), GDRAM2NRAM);
        for (int idy = 0; idy < (end_y2-start_y); idy++) {
            float val_in = matc_get_at(src_idx, temp_y[idy], ptrIn, inHeight, src_line_buff1[fn_buff_id]);
            temp_result[fn_buff_id][idy] = val_in * (temp_y[idy] + 1 - temp_py[idy]) * (src_idx + 1 - temp_px[idx]);
            val_in = matc_get_at(src_idx, temp_y[idy]+1, ptrIn, inHeight, src_line_buff1[fn_buff_id]);
            temp_result[fn_buff_id][idy] += val_in * (temp_py[idy] - temp_y[idy]) * (src_idx + 1 - temp_px[idx]);
            val_in = matc_get_at(src_idx+1, temp_y[idy], ptrIn, inHeight, src_line_buff2[fn_buff_id]);
            temp_result[fn_buff_id][idy] += val_in * (temp_y[idy] + 1 - temp_py[idy]) * (temp_px[idx] - src_idx);
            val_in = matc_get_at(src_idx+1, temp_y[idy]+1, ptrIn, inHeight, src_line_buff2[fn_buff_id]);
            temp_result[fn_buff_id][idy] += val_in * (temp_py[idy] - temp_y[idy]) * (temp_px[idx] - src_idx);
        if (end_y == outHeight) {
            int idy2 = end_y2 - start_y;
            float val_in = matc_get_at(src_idx, temp_y[idy2], ptrIn, inHeight, src_line_buff1[fn_buff_id]);
            temp_result[fn_buff_id][idy2] = val_in * (src_idx + 1 - temp_px[idx]);
            val_in = matc_get_at(src_idx+1, temp_y[idy2], ptrIn, inHeight, src_line_buff2[fn_buff_id]);
            temp_result[fn_buff_id][idy2] += val_in * (temp_px[idx] - src_idx);
        pipe.wait_copy_nram_to_dram();
        bang::memcpy_async(pipe, ptrOut+(idx+start_x)*outHeight + start_y,
                temp_result[fn_buff_id], (end_y2-start_y)*sizeof(float), NRAM2GDRAM);
        fn_buff_id = async_buff_id; // update current buff index for next loop
    if (end_x == outWidth) {
        int idx2 = end_x2 - start_x;
        int src_idx = (int)(temp_px[idx2]);
        __memcpy(src_line_buff1[0], ptrIn+src_idx*inHeight, inHeight*sizeof(float), GDRAM2NRAM);
            float val_in = matc_get_at(src_idx, temp_y[idy], ptrIn, inHeight, src_line_buff1[0]);
            temp_result[0][idy] = val_in * (temp_y[idy] + 1 - temp_py[idy]);
            val_in = matc_get_at(src_idx, temp_y[idy]+1, ptrIn, inHeight, src_line_buff1[0]);
            temp_result[0][idy] += val_in * (temp_py[idy] - temp_y[idy]);
            float val_in = matc_get_at(inWidth-1, inHeight-1, ptrIn, inHeight, NULL);
            temp_result[0][idy2] = val_in;
        __memcpy(ptrOut+(idx2+start_x)*outHeight + start_y,
                    temp_result[0], (end_y2-start_y)*sizeof(float), NRAM2GDRAM);
