使用异步传输(overlapping),测试执行时间没有得到改善 已完结 hxf02232021-06-23 10:25:07 回复 3 查看 使用求助 经验交流
#define BLOCK_SIZE      2048
#define CORE_DIM        4
#define STAGE           2
__mlu_func__ void kernel_row_mul_addb(float* __restrict__ nC,
                                        float* __restrict__ nA,
                                        float* __restrict__ nB, int colNum) {
    for (int i = 0; i < colNum; i++) {
        nC[i] += nA[i] * nB[i];
__mlu_func__ void kernel_row_mul_add(float* __restrict__ gA,
                                        float* __restrict__ gB,
                                        float* __restrict__ gC,
                                        int colNum, int rowNum, int rowA1, int rowA2) {
    //__mlu_shared__ float shr_buffb[STAGE * CORE_DIM * BLOCK_SIZE];
    //__mlu_shared__ float shr_buffc[CORE_DIM * BLOCK_SIZE];
    __nram__ float nbuffa[BLOCK_SIZE];
    __nram__ float nbuffc[BLOCK_SIZE];
    __nram__ float nbuffb[BLOCK_SIZE*STAGE];
    bang::pipeline pipe0(0);
    bang::pipeline pipe1(1);
    bang::pipeline pipe4(2);
    bang::pipeline pipe5(3);
    for ( int row = rowA1; row < rowA2; row++ ) {
        size_t cp_sizeb = colNum * sizeof(float);
        __bang_write_zero(nbuffc, BLOCK_SIZE);
        bang::memcpy_async(pipe4, nbuffa,
            gA+row*colNum, cp_sizeb, GDRAM2NRAM);
        pipe4.wait_copy_dram_to_nram();
        for (int rowb = 0; rowb = rowNum) return;
    if (end_row > rowNum) end_row = rowNum;
    kernel_row_mul_add(gA, gB, gC, colNum, rowNum, start_row, end_row);
int matrixMul(float* ptrC, float* ptrA, float* ptrB, int rowNum, int colNum) {
    float* deva, *devb, *devc;
    cnrtQueue_t queue;
    CNRT_CHECK( cnrtCreateQueue(&queue) );
    const size_t mem_size = rowNum * colNum * sizeof(float);
    CNRT_CHECK( cnrtMalloc((void**)(&deva), mem_size) );
    CNRT_CHECK( cnrtMalloc((void**)(&devb), mem_size) );
    CNRT_CHECK( cnrtMalloc((void**)(&devc), mem_size) );
    /*CNRT_CHECK( cnrtMemcpy(deva, ptrA, mem_size, CNRT_MEM_TRANS_DIR_HOST2DEV) );
    CNRT_CHECK( cnrtMemcpy(devb, ptrB, mem_size, CNRT_MEM_TRANS_DIR_HOST2DEV) );
    CNRT_CHECK( cnrtMemcpy(devc, ptrC, mem_size, CNRT_MEM_TRANS_DIR_HOST2DEV) ); */
    CNRT_CHECK( cnrtMemcpyAsync(deva, ptrA, mem_size, queue, CNRT_MEM_TRANS_DIR_HOST2DEV) );
    CNRT_CHECK( cnrtMemcpyAsync(devb, ptrB, mem_size, queue, CNRT_MEM_TRANS_DIR_HOST2DEV) );
    CNRT_CHECK( cnrtMemcpyAsync(devc, ptrC, mem_size, queue, CNRT_MEM_TRANS_DIR_HOST2DEV) );
    // Create cnrt event handles.
    cnrtNotifier_t start, stop;
    CNRT_CHECK( cnrtCreateNotifier(&start) );
    CNRT_CHECK( cnrtCreateNotifier(&stop) );
    // Record timer start
    CNRT_CHECK( cnrtPlaceNotifier(start, queue) );
    cnrtDim3_t dim = {16, 1, 1};
    cnrtFunctionType_t ktype = CNRT_FUNC_TYPE_UNION4;
    kernelMM<<>>(deva, devb, devc, rowNum, colNum);
    // Record timer stop
    CNRT_CHECK( cnrtPlaceNotifier(stop, queue) );
    CNRT_CHECK( cnrtSyncQueue(queue) );
    CNRT_CHECK( cnrtMemcpy(ptrC, devc, mem_size, CNRT_MEM_TRANS_DIR_DEV2HOST) );
    float usecTotal = 0.0f;
    CNRT_CHECK(cnrtNotifierDuration(start, stop, &usecTotal));
    printf("time spent executing by the MLU: %.3f ms\n", usecTotal / (1000));
    CNRT_CHECK( cnrtFree((void*)deva) );
    CNRT_CHECK( cnrtFree((void*)devb) );
    CNRT_CHECK( cnrtFree((void*)devc) );
    CNRT_CHECK( cnrtDestroyQueue(queue) );
    return 0;
int bang_dev_init() {
    cnrtDev_t dev;
    CNRT_CHECK(cnrtInit(0));
    CNRT_CHECK(cnrtGetDeviceHandle(&dev, 0));
    CNRT_CHECK(cnrtSetCurrentDevice(dev));
    return 0;
int bang_dev_deinit() {
    cnrtDestroy();
    return 0;
