使用live555 在linux下搭建 rtsp server 含含2020-12-21 17:17:03 回复 查看
1. live555源码下载以及编译
wget  http://www.live555.com/liveMedia/public/live555-latest.tar.gz
tar xzf live555-latest.tar.gz
cd live
./genMakefiles linux-64bit    #注意后面这个参数是根据当前文件夹下config.<后缀>获取得到的
make
2.启动live555MediaServer备注:
a.编译完成后会当前目录下生成mediaServer 文件夹,有一个live555MediaServer可执行文件;
b.可以将需要推送的视频或者音频放到live555MediaServer 目录,运行后即可推送;
cd mediaServer
./live555MediaServer
$ ./live555MediaServer
LIVE555 Media Server
	version 1.04 (LIVE555 Streaming Media library version 2020.08.12).
Play streams from this server using the URL
	rtsp://10.100.8.66:8554/<filename>
where <filename> is a file present in the current directory.
Each file's type is inferred from its name suffix:
	".264" => a H.264 Video Elementary Stream file
	".265" => a H.265 Video Elementary Stream file
	".aac" => an AAC Audio (ADTS format) file
	".ac3" => an AC-3 Audio file
	".amr" => an AMR Audio file
	".dv" => a DV Video file
	".m4e" => a MPEG-4 Video Elementary Stream file
	".mkv" => a Matroska audio+video+(optional)sub s file
	".mp3" => a MPEG-1 or 2 Audio file
	".mpg" => a MPEG-1 or 2 Program Stream (audio+video) file
	".ogg" or ".ogv" or ".opus" => an Ogg audio and/or video file
	".ts" => a MPEG Transport Stream file
		(a ".tsx" index file - if present - provides server 'trick play' support)
	".vob" => a VOB (MPEG-2 video with AC-3 audio) file
	".wav" => a WAV Audio file
	".webm" => a WebM audio(Vorbis)+video(VP8) file
See http://www.live555.com/mediaServer/ for additional documentation.
(We use port 8000 for optional RTSP-over-HTTP tunneling, or for HTTP live streaming (for indexed Transport Stream files only).)
备注:
a.将cars.mkv文件《cars.mkv》复制到和上面live555MediaServer可执行文件的同一个目录,可用vlc在打开网络中输入地址 rtsp://10.100.8.66/cars.mkv 播放视频或者音乐了。
b.启动了一个 rtsp server 可以看到当前支持的视频格式;
参考链接:https://www.cnblogs.com/dpf-10/p/5623101.html
