离线推理模型转换出错 Wxy2021-02-22 13:51:07 回复 1 查看 思元220 经验交流
离线推理模型转换出错
进行离线推理时,生成李先模型需要模型转换,遇到了问题
已经完成了原yolov4模型的量化过程,生成了int8,未产生报错
在进行yolov4的pb模型转cambricon模型的过程中出现(执行 ./tensorflow_pb_to_cambricon.sh yolov4 int8 1 1 small MLU220 命令)
F tensorflow/core/kernels/mlu_kernels/mlu_ops/mlu_ op.cc:43][6177] 'reinterpret_cast<cnnlHandle_t>(context->op_device_context() ->stream() ->implementation() ->GpuStreamMemberHack())' Must be non NULL
模型描述文件
model_name: yolov_608.cambricon
session_run{
input_nodes(1):
"Placeholder",2,608,608,3
output_nodes(3):
"concat_9"
"concat_10"
"concat_11"
量化使用的batch_size为2,608x608的彩色图片
定位源码发现
错误出现在下面那个GpuStreamMemberHack(),应该是他返回了空
查看第二个的GpuStreamMemberHack()说明后,即下面的
See the above comment on GpuStreamHack -- this further breaks abstraction
for Eigen within distbelief, which has strong ties to CUDA or ROCm as a
platform, and a historical attachment to a programming model which takes a
stream-slot rather than a stream-value.
应该是说参照上面的GpuStreamHack,应该是那个未被编译的那部分
Returns the GPU stream associated with this platform's stream implementation.
WARNING: checks that the underlying platform is, in fact, CUDA or ROCm,causing a fatal error if it is not. This hack is made available solely foruse from distbelief code, which temporarily has strong ties to CUDA or ROCm as a platform
应该是说检查平台是否为CUDA或ROCm,但由于是虚拟机因此并没有显卡。
请问这个错误应该怎么解决
