是否支持stable-diffusion yue_water2024-01-03 11:29:02 回复 2 查看 使用求助 经验交流
安装Cambricon PyTorch后,通过安装stable-diffusion,提示Torch is not able to use GPU;请问有什么好的解决办法?
GPU型号:MLU370-M8
【使用操作系统】必填*:
例如:ubuntu 20.04
【使用驱动版本】必填*:
| CNMON v5.10.12                                               Driver v5.10.12 |
| Card  VF  Name       Firmware |               Bus-Id | Util        Ecc-Error |
| Fan   Temp      Pwr:Usage/Cap |         Memory-Usage | SR-IOV   Compute-Mode |
| 0     /   MLU370-M8    v1.1.4 |         0000:A9:00.0 | 0%                N/A |
|  0%   26C         53 W/ 300 W | 28492 MiB/ 47868 MiB | N/A           Default |
| 1     /   MLU370-M8    v1.1.4 |         0000:D2:00.0 | 0%                N/A |
|  0%   24C         50 W/ 300 W |     0 MiB/ 47868 MiB | N/A           Default |
| Processes:        |
|  Card  MI  PID     Command Line                             MLU Memory Usage |
|  0     /   18976   /torch/venv3/pytorch/bin/python                 28396 MiB |
【当前已做了哪些信息确认】:
例如:已经装过Cambricon PyTorch 1.13
【出错信息】*:Torch is not able to use GPU
  File "/stable_diffusion/Project/stable-diffusion-webui/launch.py", line 48, in <module>
    main()
  File "/stable_diffusion/Project/stable-diffusion-webui/launch.py", line 39, in main
    prepare_environment()
  File "/stable_diffusion/Project/stable-diffusion-webui/modules/launch_utils.py", line 384, in prepare_environment
    raise RuntimeError(
RuntimeError: Torch is not able to use GPU; add --skip-torch-cuda-test to COMMANDLINE_ARGS variable to disable this check
