我在运行yolov5网络的 生成离线模型时 出现警告
warnings.warn(msg, SourceChangeWarning) /workspace/volume/private/sdk/venv/pytorch/lib/python3.7/site-packages/torch/serialization.py:574: SourceChangeWarning: source code of class 'torch.nn.modules.container.ModuleList' has changed. you can retrieve the original source code by accessing the 's source attribute or set `torch.nn.Module.dump_patches = True` and use the patch tool to revert the changes.
在我设定之后出现了下面的patch文件。这个是自动将我的代码中的某些函数进行修改替换吗?
