yolov3后处理问题 已解决 止战之殇2021-11-12 12:00:33 回复 2 查看 使用求助
yolov3后处理问题
    const size_t stride = max_box_ * 7  + (64);
    // std::cout << "batch size = " << batch_size_ << std::endl;
    for(size_t i = 0; i < batch_size_; i++)
        float* ptr = static_cast<float*>(data[0]) + i * stride;
        size_t bbox_num = static_cast<int>(ptr[0]);
        // std::cout << "img#" << i << " has " << bbox_num << " s" << std::endl;
        for ( size_t box_index = 0; box_index < bbox_num; box_index++)
            uint32_t add_offset = box_index * 7 + 64;
            // std::cout << "bbox#" << box_index << " : batch id = " << ptr[add_offset + 0]
            //             << " class id = " << ptr[add_offset + 1] << " confidence = " <<
            //             ptr[add_offset + 2] << " x1 = " << ptr[add_offset + 3] << " y1 = "
            //             << ptr[add_offset + 4] << " x2 = " << ptr[add_offset + 5]
            //             << "y2 = " << ptr[add_offset + 6] << std::endl;
            if(ptr[add_offset + 2] > 0.05){
                bbox boundingbox(limit(ptr[add_offset + 3]), limit(ptr[add_offset + 4]), limit(ptr[add_offset + 5])
                            , limit(ptr[add_offset + 6]), ptr[add_offset + 2], uint32_t(ptr[add_offset + 1]));
                bbox_array.at(i).push_back(boundingbox);
c++ 这么解析yolov3 的输出对么 ,输入了四个视频进行模型推理,但是只推理除了一个,还有这个stride = max_box_ * 7  + (64)为什么这么计算呢
