队列同步 已完结 sys2021-12-02 22:07:40 回复 1 查看 技术答疑 使用求助
队列同步
import torch
import torch_mlu
import torch_mlu.core.mlu_quantize as mlu_quantize
import torch_mlu.core.mlu_model as ct
from torch_mlu.core.device.queue import Queue
from torch_mlu.core.mlu_model import synchronize
from common_utils import Timer
import threading
import time
import logging
from models.AlexNet import *
from models.Vgg11 import *
from models.mobilenet import *
from models.squeezenet import *
from models.ResNet50 import *
from models.googlenet import *
from models.densenet import *
ct.set_core_version("MLU270")  #设置MLU core version
logging.basicConfig(level=logging.INFO,format='%(asctime)s - %(pathname)s[line:%(lineno)d] - %(levelname)s: %(message)s')
logger = logging.getLogger("TestNets")
queue1 = Queue(-1)
def task1(queue1):
  #设置MLU core number
  ct.set_core_number(1)
  total_e2e = 0
  total_hardware = 0
  batch_size=1
  img_num=1
  #随即保存初始的权重
  net=AlexNet().eval()
  torch.save(net.state_dict(), 'test_weights.pth')
  #输入数据:1:batch 1:channel 28:height 28:width
  input_data = torch.rand((1, 3, 256, 256), dtype=torch.float)
  #利用模型量化工具对模型的权重进行量化,并保存量化后的权重
  mean = [0,0,0]
  std = [1/255,1/255,1/255]
  net_quantization = mlu_quantize.quantize_dynamic_mlu(net, {'mean':mean, 'std':std, 'firstconv':True}, dtype='int8', gen_quant=True)
  net_quantization = mlu_quantize.quantize_dynamic_mlu(net, {'firstconv':False}, dtype='int8', gen_quant=True)
  output = net_quantization(input_data)
  torch.save(net_quantization.state_dict(), 'test_quantization.pth')
  #step1  加载权重
  net_quantization = mlu_quantize.quantize_dynamic_mlu(net)
  net_quantization.load_state_dict(torch.load('test_quantization.pth'))
  #step2  权重加载到mlu上
  net_mlu = net_quantization.to(ct.mlu_device())
  #step3  输入数据加载到mlu上
  input_mlu = input_data.to(ct.mlu_device())
  #step4  执行,输出
  timer = Timer()
  timer1 = Timer()
  output=net_mlu(input_mlu)
  total_hardware += timer1.elapsed()
  total_e2e += timer.elapsed()
  logger.info('latency: '+ str(batch_size / (img_num/total_hardware) * 1000))
  logger.info('throughput: '+ str(img_num/total_e2e))
if __name__ == '__main__':
   total_hardware = 0
   timer = Timer()
   t1 = threading.Thread(target=task1,args=(queue1,))
   t1.start()
   synchronize()
   total_hardware += timer.elapsed()
   logger.info('总耗时:'+ str(total_hardware * 1000))
您好,我想实现队列内任务的同步,但出现了下面的问题,不知道应该怎么修改呢,感谢
