#include "cnrt.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include"cnpy.h"
#include<complex>
#include<cstdlib>
#include<iostream>
#include<map>
#include<string>
#include <opencv/cv.h>
#include <opencv/highgui.h>
using namespace cv;
using namespace std;
void cnpy2opencv_3d(std::string const& data_fname, cv::Mat& out)
// Load the data from file
cnpy::NpyArray npy_data = cnpy::npy_load(data_fname);
// Get pointer to data
float* ptr = npy_data.data<float>();
// Get the shape of data
int dim_1 = npy_data.shape[0];
int dim_2 = npy_data.shape[1];
int dim_3 = npy_data.shape[2];
int size[3] = { dim_1, dim_2, dim_3 };
out = cv::Mat(3, size, CV_32F, ptr).clone();
ptr+=(dim_2*dim_1*3);
int offline_test(const char *name) {
// This example is used for MLU270 and MLU220. You need to
// choose the corresponding offline model.
// when generating an offline model, u need cnml and cnrt both
// when running an offline model, u need cnrt only
cnrtInit(0);
// prepare model name
char fname[100] = "../offline/";
// The name parameter represents the name of the offline model file.
// It is also the name of a function in the offline model file.
strcat(fname, name);
strcat(fname, ".cambricon");
printf("load file: %s\n", fname);
// load model
cnrtModel_t model;
cnrtLoadModel(&model, fname);
cnrtDev_t dev;
cnrtGetDeviceHandle(&dev, 0);
cnrtSetCurrentDevice(dev);
// get model total memory
int64_t totalMem;
cnrtGetModelMemUsed(model, &totalMem);
printf("total memory used: %ld Bytes\n", totalMem);
// get model parallelism
int model_parallelism;
cnrtQueryModelParallelism(model, &model_parallelism);
printf("model parallelism: %d.\n", model_parallelism);
int func_num = 0;
cnrtGetFunctionNumber(model, &func_num);
printf("model function number is %d\n", func_num);
// load extract function
cnrtFunction_t function;
cnrtCreateFunction(&function);
cnrtExtractFunction(&function, model, name);
int inputNum, outputNum;
int64_t *inputSizeS, *outputSizeS;
cnrtGetInputDataSize(&inputSizeS, &inputNum, function);
cnrtGetOutputDataSize(&outputSizeS, &outputNum, function);
// prepare data on cpu
void **inputCpuPtrS = (void **)malloc(inputNum * sizeof(void *));
void **outputCpuPtrS = (void **)malloc(outputNum * sizeof(void *));
int input_idx=0;
int output_idx=0;
unsigned char *ptr=(unsigned char *)inputCpuPtrS[input_idx];
cv::Mat test_data;
string string_i;
string image_path = "/workspace/astro/dataset_npy/img";
string new_image_path;
// allocate I/O data memory on MLU
void **inputMluPtrS = (void **)malloc(inputNum * sizeof(void *));
void **outputMluPtrS = (void **)malloc(outputNum * sizeof(void *));
// prepare input buffer
for (int i = 0; i < inputNum; i++) {
// converts data format when using new interface model
inputCpuPtrS[i] = malloc(inputSizeS[i]);
string_i = to_string(i);
new_image_path = image_path.append(string_i);
new_image_path = new_image_path.append(".npy");
cnpy2opencv_3d(new_image_path, test_data);
// malloc mlu memory
cnrtMalloc(&(inputMluPtrS[i]), inputSizeS[i]);
cnrtMemcpy(inputMluPtrS[i], inputCpuPtrS[i], inputSizeS[i], CNRT_MEM_TRANS_DIR_HOST2DEV);
// prepare output buffer
for (int i = 0; i < outputNum; i++) {
outputCpuPtrS[i] = malloc(outputSizeS[i]);
cnrtMalloc(&(outputMluPtrS[i]), outputSizeS[i]);
// prepare parameters for cnrtInvokeRuntimeContext
void **param = (void **)malloc(sizeof(void *) * (inputNum + outputNum));
for (int i = 0; i < inputNum; ++i) {
param[i] = inputMluPtrS[i];
for (int i = 0; i < outputNum; ++i) {
param[inputNum + i] = outputMluPtrS[i];
// setup runtime ctx
cnrtRuntimeContext_t ctx;
cnrtCreateRuntimeContext(&ctx, function, NULL);
// bind device
cnrtSetRuntimeContextDeviceId(ctx, 0);
cnrtInitRuntimeContext(ctx, NULL);
// compute offline
cnrtQueue_t queue;
cnrtRuntimeContextCreateQueue(ctx, &queue);
// invoke
cnrtInvokeRuntimeContext(ctx, param, queue, NULL);
// sync
cnrtSyncQueue(queue);
// copy mlu result to cpu
cnrtMemcpy(outputCpuPtrS[i], outputMluPtrS[i], outputSizeS[i], CNRT_MEM_TRANS_DIR_DEV2HOST);
// free memory space
free(inputCpuPtrS[i]);
cnrtFree(inputMluPtrS[i]);
free(outputCpuPtrS[i]);
cnrtFree(outputMluPtrS[i]);
free(inputCpuPtrS);
free(outputCpuPtrS);
free(param);
cnrtDestroyQueue(queue);
cnrtDestroyRuntimeContext(ctx);
cnrtDestroyFunction(function);
cnrtUnloadModel(model);
cnrtDestroy();
return 0;
int main() {
printf("offline test\n");
offline_test("q_model");
return 0;
我保存的离线文件.cambricon文件,在上一级目录的offline文件夹下。输入数据在上级目录的get_numpy文件夹下,因为是.npy格式的,我是先转到opencv的mat中(每一个npy文件是224*224*3的),如下图:
出现了core dump的错误,求各位大佬帮我看看
我怀疑是我数据输入那块出现了问题,因为我看的离线模型示例里边很少有数据输到cpu这步,所以我怀疑我这步写错了
谢谢各位大佬的帮助!
