【CNPlugin】求助,PluginOp测试出错 已完结 wanjifeng2022-06-30 10:02:44 回复 8 查看 技术答疑
【寒武纪硬件产品型号】必填*:MLU270
【使用操作系统】必填*:ubuntu16
【使用驱动版本】必填*: v4.9.2
【出错信息】必填*:
CNML: 7.10.2 ba20487
CNRT: 4.10.1 a884a9a
2022-06-30 09:10:37.015295: [cnmlError] cnml_ _op_ptr is nullptr
2022-06-30 09:10:37.015309: [cnmlError] cnml_ _op_ptr is nullptr
【出错代码链接】选填:
  // Create op_ptr
  cnml Op_t op;
  cnmlCreatePluginConv3dOp(&op, param, cnml_input_tensor,cnml_filter_tensor,cnml_ _tensor, cnml_output_tensor);
  // Set op layout
  cnmlSetOperationComputingLayout(op, CNML_NDHWC);
  // Compile op
  cnmlCompile Op(op, CNML_MLU270, 4);
完整代码:
int main() {
  // Yolov3DetectionOutputOp performs the computation described in the yolo-  proposed by
  // like cnrtMalloc.
  cnmlInit(0);
  unsigned dev_num;
  CNRT_CHECK(cnrtGetDeviceCount(&dev_num));
  if (dev_num == 0)
    return CNRT_RET_ERR_NODEV;
  cnrtDev_t dev;
  CNRT_CHECK(cnrtGetDeviceHandle(&dev, 0));
  CNRT_CHECK(cnrtSetCurrentDevice(dev));
  // Prepare params & data for yolov3 detection op
  Conv3dOpParam p1;
  p1.input_n=1;
  p1.input_d=16;
  p1.input_h=300;
  p1.input_w=256;
  p1.input_c=16;
  p1.output_d=16;
  p1.output_h=300;
  p1.output_w=256;
  p1.output_c=128;
  p1.kd=3;
  p1.kh=3;
  p1.kw=3;
  p1.stride_d=1;
  p1.stride_h=1;
  p1.stride_w=1;
  p1.dilation_d=1;
  p1.dilation_h=1;
  p1.dilation_w=1;
  p1.pad_d_back=0;
  p1.pad_d_front=0;
  p1.pad_h_back=0;
  p1.pad_h_front=0;
  p1.pad_w_back=0;
  p1.pad_w_front=0;
  cnmlCoreVersion_t core_version = CNML_MLU270;
  cnmlDataType_t data_type;
  cnrtDataType_t cast_type;
  int data_width = 0;
  data_type = CNML_DATA_INT8;
  cast_type = CNRT_INT8;
  data_width = 1;
  // Create params for yolov3 detection op.
  cnmlPluginConv3dOpParam_t param;
  cnmlCreatePluginConv3dOpParam(
      &param, p1.input_n,p1.input_d,p1.input_h,p1.input_w,p1.input_c,p1.output_d,p1.output_h,p1.output_w,
      p1.output_c,p1.kd,p1.kh,p1.kw,p1.stride_d,p1.stride_h,p1.stride_w,p1.dilation_d,p1.dilation_h,
      p1.dilation_w,p1.pad_d_front,p1.pad_d_back,p1.pad_h_front,p1.pad_h_back,p1.pad_w_front,p1.pad_w_back,1,false,0xFFFF,1.0,0xFFFF,1.0,data_type,core_version);
  cnmlTensor_t *cnml_input_tensor = (cnmlTensor_t *)malloc(sizeof(cnmlTensor_t));
  cnmlTensor_t *cnml_filter_tensor = (cnmlTensor_t *)malloc(sizeof(cnmlTensor_t));
  cnmlTensor_t *cnml_ _tensor = (cnmlTensor_t *)malloc(sizeof(cnmlTensor_t) );
  cnmlTensor_t *cnml_output_tensor = (cnmlTensor_t *)malloc(sizeof(cnmlTensor_t) );
  cnmlCreateTensor_V2(&cnml_input_tensor[0], CNML_TENSOR);
  cnmlCreateTensor_V2(&cnml_filter_tensor[0], CNML_TENSOR);
  cnmlCreateTensor_V2(&cnml_ _tensor[0], CNML_TENSOR);
  cnmlCreateTensor_V2(&cnml_output_tensor[0], CNML_TENSOR);
  // Create op_ptr
  cnml Op_t op;
  // Set op layout
  // Compile op
