CNStream执行cmake构建时出错 已解决 wmatrix2021-06-22 21:00:14 回复 5 查看 使用求助
按照手册文档clone CNStream仓库后,成功执行
pre_required_helper.sh
进行了依赖安装,但是执行cmake编译时提示错误,输出如下:
lzh@ssk-ThinkStation-P520:~/CNStream/build$ cmake ..
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Performing Test COMPILER_SUPPORTS_CXX11
-- Performing Test COMPILER_SUPPORTS_CXX11 - Success
generate default(MLU270) Makefile
-- Found GFlags: /usr/include
-- Found gflags  (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libgflags.so)
-- Found Glog: /usr/include
-- Found glog    (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libglog.so)
-- HAVE_OPENCV enabled
-- opencv libraries: opencv_imgcodecs;opencv_videoio;opencv_core;opencv_imgproc;opencv_highgui;opencv_features2d
-- HAVE_FFMPEG enabled
-- ffmpeg include: /usr/include/x86_64-linux-gnu
-- ffmpeg libraries: /usr/lib/x86_64-linux-gnu/libavcodec.so;/usr/lib/x86_64-linux-gnu/libavformat.so;/usr/lib/x86_64-linux-gnu/libavutil.so;/usr/lib/x86_64-linux-gnu/libswscale.so;/usr/lib/x86_64-linux-gnu/libswresample.so
-- SDL2 Found
-- Found PythonInterp: /usr/bin/python (found version "2.7.17")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- CMAKE_INSTALL_PREFIX = /home/lzh/CNStream/easydk/dist
-- !!!!! BUILD RELEASE !!!!!
-- generate default (MLU200 CLOUD) Makefile
------------------- Turbo-JPEG and libyuv -----------------------
-- CMAKE_BUILD_TYPE = RELEASE
-- VERSION = 2.0.6, BUILD = 20210622
-- 64-bit build (x86_64)
-- Shared libraries disabled (ENABLE_SHARED = 0)
-- Static libraries enabled (ENABLE_STATIC = 1)
-- 12-bit JPEG support disabled (WITH_12BIT = 0)
-- Arithmetic decoding support disabled (WITH_ARITH_DEC = 0)
-- Arithmetic encoding support disabled (WITH_ARITH_ENC = 0)
-- TurboJPEG API library enabled (WITH_TURBOJPEG = 1)
-- TurboJPEG Java wrapper disabled (WITH_JAVA = 0)
-- In-memory source/destination managers enabled (WITH_MEM_SRCDST = 1)
-- Emulating libjpeg API/ABI v6.2 (WITH_JPEG7 = 0, WITH_JPEG8 = 0)
-- libjpeg API shared library version = 62.3.0
-- Compiler flags =  -D_REENTRANT -fPIC -fvisibility=hidden -O3 -DNDEBUG
--  er flags =
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of size_t
-- Check size of size_t - done
-- Check size of unsigned long
-- Check size of unsigned long - done
-- Performing Test HAVE_BUILTIN_CTZL
-- Performing Test HAVE_BUILTIN_CTZL - Success
-- Looking for include file locale.h
-- Looking for include file locale.h - found
-- Looking for include file stdlib.h
-- Looking for include file stdlib.h - found
-- Looking for include file sys/types.h
-- Looking for include file sys/types.h - found
-- Looking for memset
-- Looking for memset - found
-- Looking for memcpy
-- Looking for memcpy - found
-- Check size of unsigned char
-- Check size of unsigned char - done
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Performing Test INCOMPLETE_TYPES
-- Performing Test INCOMPLETE_TYPES - Success
-- Compiler supports pointers to undefined structures.
-- Performing Test RIGHT_SHIFT_IS_UNSIGNED
-- Performing Test RIGHT_SHIFT_IS_UNSIGNED - Failed
-- Performing Test __CHAR_UNSIGNED__
-- Performing Test __CHAR_UNSIGNED__ - Failed
-- Performing Test INLINE_WORKS
-- Performing Test INLINE_WORKS - Success
-- INLINE = __inline__ __attribute__((always_inline)) (FORCE_INLINE = 1)
-- Performing Test HAVE_THREAD_LOCAL
-- Performing Test HAVE_THREAD_LOCAL - Success
-- THREAD_LOCAL = __thread
-- Performing Test HAVE_VERSION_
-- Performing Test HAVE_VERSION_  - Success
--  er supports GNU-style version  s
-- CMAKE_EXECUTABLE_SUFFIX =
-- Looking for a ASM_NASM compiler
-- Looking for a ASM_NASM compiler - NOTFOUND
CMake Warning at easydk/3rdparty/libjpeg-turbo/simd/CMakeLists.txt:5 (message):
  SIMD extensions disabled: could not find NASM compiler.  Performance will
  suffer.
Call Stack (most recent call first):
  easydk/3rdparty/libjpeg-turbo/simd/CMakeLists.txt:45 (simd_fail)
-- FLOATTEST = 32bit
------------------- Turbo-JPEG and libyuv END -----------------------
-- Could NOT find libdw (missing: LIBDW_LIBRARY LIBDW_INCLUDE_DIR)
-- Could NOT find libbfd (missing: LIBBFD_LIBRARY LIBBFD_INCLUDE_DIR)
-- Could NOT find libdwarf (missing: LIBDWARF_LIBRARY LIBDWARF_INCLUDE_DIR LIBELF_LIBRARY LIBELF_INCLUDE_DIR)
-- Found Backward: /home/lzh/CNStream/easydk/3rdparty/backward
-- Build with EasyInfer
-- Build with EasyCodec
-- Build with EasyTrack
-- Build with EasyBang
-- @@@@@@@@@@@ Target : easydk
-- @@@@@@@@@@@ Target : cnis
-- Could NOT find LibRDKafka (missing: LibRDKafka_C_LIBRARIES LibRDKafka_INCLUDE_DIR)
CMake Error at modules_contrib/CMakeLists.txt:9 (message):
  rdkafka not found
-- Configuring incomplete, errors occurred!
See also "/home/lzh/CNStream/build/CMakeFiles/CMakeOutput.log".
See also "/home/lzh/CNStream/build/CMakeFiles/CMakeError.log".
