MLU100-B5驱动安装出现问题 已完结 Reus2019-11-17 21:05:24 回复 10 查看 Driver
MLU100-B5驱动安装出现问题
主机配置如下:
操作系统:ubuntu16.04.5
内核版本:4.15.0-70-generic
安装驱动版本:3.5.1
板卡型号:MLU100-B5
输入sudo apt install ./neuware-driver-dkms_3.5.1_all.deb后显示:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'neuware-driver-dkms' instead of './neuware-driver-dkms_3.5.1_all.deb'
The following NEW packages will be installed:
  neuware-driver-dkms
0 upgraded, 1 newly installed, 0 to remove and 420 not upgraded.
Need to get 0 B/8,585 kB of archives.
After this operation, 18.5 MB of additional disk space will be used.
Get:1 /home/para542/Documents/MLU/driver/neuware-driver-dkms_3.5.1_all.deb neuware-driver-dkms all 3.5.1 [8,585 kB]
Selecting previously unselected package neuware-driver-dkms.
(Reading data  ... 217124 files and directories currently installed.)
Preparing to unpack .../neuware-driver-dkms_3.5.1_all.deb ...
APT already is root
Unpacking neuware-driver-dkms (3.5.1) ...
Setting up neuware-driver-dkms (3.5.1) ...
Loading new neuware-driver-3.5.1 DKMS files...
First Installation: checking all kernels...
Building only for 4.15.0-70-generic
Building for architecture x86_64
Building initial module for 4.15.0-70-generic
Secure Boot not enabled on this system.
Done.
cambricon_c10_driver:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.15.0-70-generic/updates/dkms/
cnmon_device.ko:
 - Original module
 - Installation
cncodec_driver.ko:
 - Original module
 - Installation
Running the post_install  :
mlu100 device count: 1
need training count:1
some ddr config file not exist in your system,so ddr will training long time,at least 2 minute.
TO insmod module cambricon_c10.
cambricon_c10_driver  2260992  0
Note: The cambricon_c10_driver.ko has been loaded!
Note: The new cambricon_c10_driver.ko will been loaded automatically after system reboot!
depmod....
DKMS: install completed.
然后reboot重启,之后输入cnmon无法显示正常信息,而是:
Segmentation fault (core dumped)
输入dpkg -l neuware-driver-dkms显示:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                                 Version                 Architecture            De ion
ii  neuware-driver-dkms                  3.5.1                   all                     neuware-driver driver in DKMS format.
请问现在应该怎么办????
