__bang_reshape_nchw2nhwc BUG? guozhenjiang2020-06-15 21:17:31 回复 2 查看 实验支持 思元270 BANG语言
下面是__bang_reshape_nchw2nhwc的文档描述:
void __bang_reshape_nchw2nhwc (half* dst, half* src, int n, int h, int w, int c)
void __bang_reshape_nchw2nhwc (short* dst, short* src, int n, int h, int w, int c)
void __bang_reshape_nchw2nhwc (unsigned short* dst, unsigned short* src, int n, int h, int w,
int c)
void __bang_reshape_nchw2nhwc (int8* dst, int8* src, int n, int h, int w, int c)
void __bang_reshape_nchw2nhwc (char* dst, char* src, int n, int h, int w, int c)
void __bang_reshape_nchw2nhwc (unsigned char* dst, unsigned char* src, int n, int h, int w, int
c)
void __bang_reshape_nchw2nhwc (float* dst, float* src, int n, int h, int w, int c)
void __bang_reshape_nchw2nhwc (int* dst, int* src, int n, int h, int w, int c)
void __bang_reshape_nchw2nhwc (unsigned int* dst, unsigned int* src, int n, int h, int w, int c)
Reshape the kernel from NCHW to NHWC.
• Parameters:
<dst> The address of destination vector
<src> The address of source vector
<n> Batch number of kernel
<h> Height of kernel
<w> Width of kernel
<c> Channel input of kernel
• Remarks
1. The interface is supported on MLU270;
2. The operand <src> must point to __nram__ space;
3. The operand <dst> must point to __nram__ space;
4. <h> * <w> * sizeof(src) must be dividable by 64;
5. <c> * sizeof(src) must be dividable by 64.
但在实际中发现,4,5两条并没有被实际检查,取而代之的是会检查c是否能被32整除。例如(n,h,w,c) = (1,1,1,32)可以通过编译,而(1,1,32,2)不能
