关于CNStream解码速率问题 已完结 FrostLee2023-01-13 17:29:12 回复 3 查看 技术答疑 使用求助 经验交流
关于CNStream解码速率问题
【寒武纪硬件产品型号】必填*:MLU220
【使用操作系统】必填*:Ubuntu 18.04.5 LTS
【使用驱动版本】必填*:CNRT: 4.10.2 adb709e
【问题】:我暂时没有使用推理模块,想先把16路视频流使用rtsp调试到最流畅,视频是720P,json配置如下。
config.json
  "profiler_config" : {
    "enable_profiling" : true,
    "enable_tracing" : false
  "subgraph:decode" : {
    "config_path" : "../configs/decode_config.json",
    "next_modules" : ["subgraph:sinker"]
  "subgraph:sinker" : {
    "config_path" : "../configs/sinker_configs/__SINKER_PLACEHOLDER__"
decode_config.json
  "source" : {
    "class_name" : "cnstream::DataSource",
    "custom_params" : {
      "reuse_cndec_buf" : "true",
      "output_type" : "mlu",
      "decoder_type" : "mlu",
      "output_buf_number" : 1,
      "input_buf_number" : 1,
      "device_id" : 0
请教一下output_buf_numberinput_buf_number要怎么设置?看了文档不是很理解,好像并不是越大越好。
另外,两个值的上限是多少?
不设置的默认值是多少?
为什么设置的值大了会导致16路显示不全?
output_buf_number=1且input_buf_number=1 日志】:
**********************  Performance Print Start  (Whole)  **********************
===========================  Pipeline: [MyPipeline]  ===========================
---------------------- Module: [MyPipeline/decode/source] ---------------------- (slowest)
----------Process Name: [PROCESS]
[Counter]: 28588, [Throughput]: 256.211fps
--------------------- Module: [MyPipeline/sinker/rtsp_sink] --------------------
----------Process Name: [INPUT_QUEUE]
[Counter]: 28562, [Throughput]: 258.86fps
[Counter]: 28561, [Throughput]: 298.274fps
-----------------------------------  Overall  ----------------------------------
[Counter]: 28561, [Throughput]: 255.973fps
***********************  Performance Print End  (Whole)  ***********************
output_buf_number=2且input_buf_number=2 日志】:
[Counter]: 52828, [Throughput]: 203.46fps
[Counter]: 52799, [Throughput]: 204.315fps
[Counter]: 52798, [Throughput]: 232.443fps
[Counter]: 52798, [Throughput]: 203.346fps
【只设置output_buf_number=16
[Counter]: 25697, [Throughput]: 184.074fps
[Counter]: 25662, [Throughput]: 190.857fps
[Counter]: 25661, [Throughput]: 218.092fps
[Counter]: 25661, [Throughput]: 183.819fps
最后再复述一下问题,
另外,两个值的上限是多少?
不设置的默认值是多少?
感谢大佬。
