k8s配置出错 gxl2024-12-03 16:06:16 回复 1 查看 使用求助
k8s配置出错
root@master1 manifests]# kubectl logs pods cambricon-device-plugin-daemonset-lrqs8 -n kube-system
Error from server (NotFound): pods "pods" not found
[root@master1 manifests]# kubectl logs pod cambricon-device-plugin-daemonset-lrqs8 -n kube-system
Error from server (NotFound): pods "pod" not found
[root@master1 manifests]# kubectl logs cambricon-device-plugin-daemonset-lrqs8 -n kube-system
time="2024-12-03T08:02:59Z" level=info msg="Parsed options: {/usr/bin/cnmon false false true info 0 best-effort default false master false 1 [] }"
time="2024-12-03T08:02:59Z" level=info msg="Final options: {/usr/bin/cnmon false false true info 0 best-effort default false master false 1 [] }"
time="2024-12-03T08:02:59Z" level=info msg="Loading CNDEV"
time="2024-12-03T08:02:59Z" level=info msg="Fetching devices."
time="2024-12-03T08:02:59Z" level=info msg="Starting FS watcher."
time="2024-12-03T08:02:59Z" level=info msg="Starting OS watcher."
time="2024-12-03T08:02:59Z" level=info msg="Starting Plugins."
time="2024-12-03T08:02:59Z" level=info msg="start serving at 0.0.0.0:30107"
time="2024-12-03T08:02:59Z" level=info msg="Starting to serve on socket /var/lib/kubelet/device-plugins/real-mlu-counts.sock"
time="2024-12-03T08:02:59Z" level=info msg="Registered resource cambricon.com/real-mlu-counts"
time="2024-12-03T08:02:59Z" level=info msg="Starting to serve on socket /var/lib/kubelet/device-plugins/cambricon.sock"
time="2024-12-03T08:02:59Z" level=info msg="Registered resource cambricon.com/mlu370"
/usr/bin/k8s-device-plugin: symbol lookup error: /usr/bin/k8s-device-plugin: undefined symbol: cndevGetXidErrorV2
cndev出错
