【MagicMind】ERROR: magicmind/utils/dl_handle.cc:18] Cannot open library: ./tmp_mm_5Msu8b due to ./tmp_mm_5Msu8b: cannot open shared object file: No such file or directory 已完结 zckx2023-10-08 10:28:38 回复 1 查看 技术答疑
【寒武纪硬件产品型号】必填*:
必填项,例如:MLU370
【MagicMind版本号】必填*:
0.14.0
【出错信息】必填*:
2023-10-08 10:25:08.004110: ERROR:  magicmind/utils/dl_handle.cc:18] Cannot open library: ./tmp_mm_5Msu8b due to ./tmp_mm_5Msu8b: cannot open shared file: No such file or directory
2023-10-08 10:25:08.005321: ERROR:  magicmind/runtime/core/model.cc:199] Create Engine failed. Failed to open the library.
./run.sh:行 101:  6577 段错误               (核心已转储)${SAMPLES_DIR}/bin/cns_launcher --data_path ${SAMPLES_DIR}/files.list_video --src_ _rate 25 --config_fname ${CURRENT_DIR}/config.json
【操作步骤】选填:
【相关日志文档】选填
如有,可附件
【出错代码链接】选填:
github的或gitee的代码的链接,https://gitee.com/cambricon/CNStream.git
