我使用的是magicmind:1.7.0-x86_64-ubuntu20.04-py_3_7镜像
执行 ./onnx_build --onnx onnx/vit-b-16.txt.fp16.onnx 报错了,
2024-07-14 02:51:46.825073: INFO: /usr/local/neuware/samples/magicmind/mm_build/main.cc:20] ==================== Parameter Information --precision<Str> : --calibration<Bool> : false --rpc_server<Str> : --calibration_algo<Str> : linear --file_list<Vec<Str>> : --calibration_data_path<Str> : --random_calib_range<Vec<Float>>: --batch_size<Vec<Int>> : --input_dims<Vec<Vec<Int>>> : --input_layout<Vec<Str>> : --input_dtypes<Vec<Str>> : --dynamic_shape<Bool> : true --vars<Vec<Vec<Float>>> : --means<Vec<Vec<Float>>> : --output_layout<Vec<Str>> : --output_dtypes<Vec<Str>> : --mlu_arch<Vec<Str>> : --mlu_product_name<Vec<Str>> : --plugin<Vec<Str>> : --magicmind_model<Str> : ./model --build_config<Str> : --toolchain_path<Str> : /usr/local/aarch64--glibc--stable-2020.08-1/ --rgb2bgr<Bool> : false --cluster_num<Vec<Vec<Int>>> : --remote_calibration_plugin<Str>: --onnx<Str> : onnx/vit-b-16.txt.fp16.onnx --external_data_dir<Str> : MagicMind: 1.7.0 error: 'onnx.Unsqueeze' op requires a single operand 2024-07-14 02:51:48.309926: ERROR: magicmind/translation/onnx/module_loader.cc:61] Failed to verify onnx mlir module error: 'onnx.Unsqueeze' op requires a single operand error: 'onnx.Unsqueeze' op requires a single operand error: 'onnx.Unsqueeze' op requires a single operand error: 'onnx.Unsqueeze' op requires a single operand 2024-07-14 02:51:48.312868: ERROR: magicmind/cc/internal/mm_parser_core.h:57] Internal: Onnx mlir graph is illegal 2024-07-14 02:51:48.319902: ERROR: /usr/local/neuware/samples/magicmind/mm_build/parser.cc:20] Internal: Onnx mlir graph is illegal Aborted (core dumped)
请教一下这个问题怎么修复。
