BangC 编译的时候cnrt的部分函数找不到,例如cnrtConvertFloatToHalf, cnrtCreateQueue等 已解决 wangyy20222022-10-26 15:41:53 回复 3 查看 技术答疑 使用求助 社区交流
./common12/mlu_gemm16.cpp: In function 'void cnrtConvertFloatToHalfArray(uint16_t*, const float*, int)':
./common12/mlu_gemm16.cpp:45:38: error: 'cnrtConvertFloatToHalf' was not declared in this scope
       cnrtConvertFloatToHalf(x+i,y[i]);
In file included from ./common12/mlu_gemm16.cpp:30:0:
./common12/mlu_gemm16.cpp: In function 'int Mlu_gemm(float*, float*, float*, int32_t, int32_t, int32_t, float&)':
./common12/mlu_gemm16.cpp:60:37: error: 'cnrtCreateQueue' was not declared in this scope
   CNRT_CHECK(cnrtCreateQueue(&pQueue));
/usr/local/bangpy_neuware_install_dir/usr/local/neuware/include/cnrt.h:5000:21: note: in definition of macro 'CNRT_CHECK'
     cnrtRet_t ret = val;                                                      \
./common12/mlu_gemm16.cpp:197:4: error: 'cnrtKernelInitParam_t' was not declared in this scope
    cnrtKernelInitParam_t init_param;
./common12/mlu_gemm16.cpp:198:42: error: 'init_param' was not declared in this scope
    CNRT_CHECK(cnrtCreateKernelInitParam(&init_param));
路径配置为usr/local/neuware/include
