自定义算子torch.ops.torch_mlu.mlunmsthresh测试报错 zjunk2023-02-23 15:21:48 回复 9 查看 技术答疑 使用求助 经验交流
老师 你好之前问题已经解决了,现在我们尝试调用该接口
detect_out = torch.ops.torch_mlu.mlunmsthresh(score.to(ct.mlu_device()),80,8400)
会报以下错误
根据提示是计算队列出错(syncQueue),可是提示中没有任何线索指向我写的代码问题,也没有思路发现问题希望老师们能帮忙看看
唯一使用到
syncQueue(queue)就是在mlunmsthresh_internal.cpp中
cnmlComputePluginPpyoloenmsOpForward
具体代码如下
#include "aten/operators/cnml/cnml_kernel.h"
namespace torch_mlu
namespace cnml
namespace ops
std::tuple<at::Tensor, at::Tensor> cnml_mlunmsthresh_internal(const at::Tensor & source,int64_t num_classes, int64_t num_anchors)
      int numclass=num_classes;
      int numanchor=num_anchors;
      cnmlTensor_t cnml_input_ptr[1];
      cnmlTensor_t cnml_output_ptr[3];
      // prepare input cnml tensor
      auto *source_impl = getMluTensorImpl(source);
      auto source_cnml = source_impl->CreateCnmlTensor(CNML_TENSOR,
      toCnmlDataType(source.dtype()));
      // prepare out cnml tensor
      // auto output_options =
      // at::TensorOptions(c10::ScalarType::Half).device(at::DeviceType::MLU);
      // auto output_bbox = at::empty({batch_size * nms_num, 4, 1, 1}, output_options);
      // auto* output_bbox_impl = getMluTensorImpl(output_bbox);
      // auto output_bbox_cnml =
      // output_bbox_impl->CreateCnmlTensor(CNML_TENSOR, CNML_DATA_FLOAT16);
      // auto* tmp_impl = getMluTensorImpl(tmp);
      // auto tmp_cnml = tmp_impl->CreateCnmlTensor(CNML_TENSOR, CNML_DATA_FLOAT16);
      //#CNML_DATA_INT32
      auto output_options1 =
      at::TensorOptions(c10::ScalarType::Int).device(at::DeviceType::MLU);
      auto output1 =at::empty({8400, 1},output_options1);
      auto *output1_impl = getMluTensorImpl(output1);
      auto output1_cnml = output1_impl->CreateCnmlTensor(CNML_TENSOR,
      CNML_DATA_INT32);
      auto output2 = at::empty({8400, 2}, output_options);
      auto* output2_impl = getMluTensorImpl(output2);
      auto output2_cnml = output2_impl->CreateCnmlTensor(
      CNML_TENSOR,CNML_DATA_FLOAT16);
      auto output3 = at::empty({16, 2}, output_options1);
      auto* output3_impl = getMluTensorImpl(output3);
      auto output3_cnml = output3_impl->CreateCnmlTensor(
      CNML_TENSOR,CNML_DATA_INT32);
      // End the execution flow if not MLU device
      CHECK_MLU_DEVICE(std::make_tuple(output1, output2));
      cnml_input_ptr[0] = source_cnml;
      cnml_output_ptr[0] = output1_cnml;
      cnml_output_ptr[1] = output2_cnml;
      cnml_output_ptr[2] = output3_cnml;
      cnmlPluginPpYoloenmsOpParam_t param;
      cnmlCreatePluginPpyoloenmsOpParam(&param,numclass,numanchor);
      cnml Op_t op;
      TORCH_CNML_CHECK(cnmlCreatePluginPpyoloenmsOp(&op,param,cnml_input_ptr,cnml_output_ptr));
      // return to JIT if running mode is fuse
      CHECK_RETURN_TO_FUSE(op, std::make_tuple(output1, output2));
      // get queue and func_param
      cnrtInvokeFuncParam_t func_param;
      static u32_t affinity = 0x01;
      int data_parallelism = 1;
      func_param.affinity = &affinity;
      func_param.data_parallelism = &data_parallelism;
      func_param.end = CNRT_PARAM_END;
      auto queue = getCurQueue();
      // compile all ops
      TORCH_CNML_CHECK(cnmlCompile Op(op,GET_CORE_VERSION,GET_CORE_NUMBER));
      void *input_addrs[1];
      void *output_addrs[3];
      input_addrs[0] = source_impl->raw_mutable_data();
      output_addrs[0] = output1_impl->raw_mutable_data();
      output_addrs[1] = output2_impl->raw_mutable_data();
      output_addrs[2] = output3_impl->raw_mutable_data();
      // compute operator
      TORCH_CNML_CHECK(cnmlComputePluginPpyoloenmsOpForward(op,
      input_addrs,
      1,
      output_addrs,
      3,
      &func_param,
      queue));
      syncQueue(queue);
      TORCH_CNML_CHECK(cnmlDestroyPluginPpyoloenmsOpParam(&param));
      TORCH_CNML_CHECK(cnmlDestroy Op(&op));
      return std::make_tuple(output1, output2);
} // namespace ops
} // namespace cnml
} // namespace torch_mlu
