【寒武纪硬件产品型号】必填*:
MLU270
【使用操作系统】必填*:
ubuntu
【使用驱动版本】必填*:
例如v4.20.6
【使用AI框架】必填*:
Pytorch
【出错信息】必填*:
在使用离线模型进行推理时报错:
(torch_mlu_py36) root@pointpillor-v1-85cbc7cd74-cc4lq:/data/xyy/yolos_offline/offline_yolos# bash run.sh CNRT: 4.10.1 a884a9a inputNum:1 outputNum:2 input shape: 1 384 640 3 output shape: 1 1 1 7232 output shape: 1 384 640 19 batchsize:1 input_image.shape:720 1280 entering yolov5 preprocess input_height:384 input_width:640 img_h:720 img_w:1280 img_scale:0.500000 input_height:384 input_width:640 new_h:360 new_w:640 [640 x 384] -----start to copy data to device------ input_idx:0 -----start to set notifier------ -----start to set parameters------ -----start to process------ run.sh: line 17: 71980 Segmentation fault (core dumped) ./build/yolos_offline model/yolov5s_int8_1b_1c_offline.cambricon subnet0 0 0 ./image/image2.jpg 2 label_map_cityscapes.txt
run.sh
【当前已做了哪些信息确认】选填:
经过调试 发现出错在算子执行步骤
#define OPENCV_TRAITS_ENABLE_DEPRECATED
#include <opencv2/core/core.hpp>
#include <opencv2/opencv.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <string>
#include <vector>
#include "cnrt.h"
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <ATen/ATen.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <dirent.h>
#include <errno.h>
#include <iostream>
#include <torch/torch.h>
#include "processor.hpp"
using namespace std;
using namespace cv;
double GetTickCount()
struct timespec ts;
clock_gettime(CLOCK_MONOTONIC, &ts);
return (ts.tv_sec * 1000000 + ts.tv_nsec / 1000)/1000.0;
int main(int argc,char *argv[])
if(argc!=8)
printf("Usage:%s model_path function_name dev_id dev_channel image_path is_rgb \n",argv[0]);
printf("\nex. ./src/yolop_offline_simple_demo model/yolop.cambricon subnet0 0 0 data/000000000872.jpg 2 \n\n");
return -1;
unsigned int dev_num=0;
CNRT_CHECK(cnrtInit(0));
CNRT_CHECK(cnrtGetDeviceCount(&dev_num));
if (dev_num == 0)
return -1;
const char *model_path=argv[1]; //模型路径
const char *function_name=argv[2]; //离线模型中的Function Name
unsigned dev_id=atoi(argv[3]); //使用的MLU 设备ID
int dev_channel=atoi(argv[4]); //使用MLU设备的通道号 -1 为自动分配
const char *image_path=argv[5]; //测试图片的路径
int is_rgb=atoi(argv[6]); //数据预处理选项
string label_filename(argv[7]); //label文件
int input_width; //网络输入的宽度
int input_height; //网络输入的高度
int batch_size; //网络的batch
int64_t *inputSizeS; //网络输入数据大小,用于分配内存
int64_t *outputSizeS; //网络输出数据量大小,用于分配内存
cnrtDataType_t *inputTypeS; //网络输入的数据类型
cnrtDataType_t *outputTypeS; //网络输出的数据类型
vector<int> output_count;
cnrtQueue_t queue; //cnrt queue
cnrtModel_t model; //离线模型
cnrtFunction_t function; //离线模型中的Function
cnrtDev_t dev; //MLU设备句柄
cnrtRuntimeContext_t ctx; //推理上下文
int *dimValues; //保存维度shape
int dimNum; //保存维度大小
int inputNum; //输入节点个数
int outputNum; //输出节点个数
void **param; //保存推理时,mlu上内存地址的指针
void **inputCpuPtrS; //输入数据的CPU指针
void **outputCpuPtrS; //输出数据的CPU指针
void **outputCpuNchwPtrS; //用来保存transpose后的NCHW数据
void **inputMluPtrS; //输入数据的MLU指针
void **outputMluPtrS; //输出数据的MLU指针
//获取指定设备的句柄
CNRT_CHECK(cnrtGetDeviceHandle(&dev, dev_id));
//设置当前使用的设备,作用于线程上下文
CNRT_CHECK(cnrtSetCurrentDevice(dev));
//加载离线模型
CNRT_CHECK(cnrtLoadModel(&model, model_path));
//创建function
CNRT_CHECK(cnrtCreateFunction(&function));
//从离线模型中提取指定的function,离线模型可以存储多个function
CNRT_CHECK(cnrtExtractFunction(&function, model, function_name));
//调用cnrtSetCurrentChannel之后 CNRT 仅在指定的通道上分配MLU内存,否则采用交织的方式分配
if(dev_channel>=0)
CNRT_CHECK(cnrtSetCurrentChannel((cnrtChannelType_t)dev_channel));
//创建运行时
CNRT_CHECK(cnrtCreateRuntimeContext(&ctx,function,NULL));
//设置运行时使用的设备ID
CNRT_CHECK(cnrtSetRuntimeContextDeviceId(ctx,dev_id));
//初始化运行时
CNRT_CHECK(cnrtInitRuntimeContext(ctx,NULL));
//创建队列
CNRT_CHECK(cnrtRuntimeContextCreateQueue(ctx,&queue));
//获取模型输入/输出 的数据大小及节点个数
CNRT_CHECK(cnrtGetInputDataSize(&inputSizeS,&inputNum,function));
CNRT_CHECK(cnrtGetOutputDataSize(&outputSizeS,&outputNum,function));
//获取模型输入/输出 的数据类型
CNRT_CHECK(cnrtGetInputDataType(&inputTypeS,&inputNum,function));
CNRT_CHECK(cnrtGetOutputDataType(&outputTypeS,&outputNum,function));
//分配 存放CPU端输入/输出地址的 指针数组
inputCpuPtrS = (void **)malloc(sizeof(void *) * inputNum);
outputCpuPtrS = (void **)malloc(sizeof(void *) * outputNum);
outputCpuNchwPtrS = (void **)malloc(sizeof(void *) * outputNum);
//分配 存放MLU端输入/输出地址的 指针数组
outputMluPtrS = (void **)malloc(sizeof(void *) * outputNum);
inputMluPtrS = (void **)malloc(sizeof(void *) * inputNum);
printf("inputNum:%d\n",inputNum);//1
printf("outputNum:%d\n",outputNum);//2
//为输入节点 分配CPU/MLU内存
for (int i = 0; i < inputNum; i++)
CNRT_CHECK(cnrtMalloc(&inputMluPtrS[i],inputSizeS[i])); //分配MLU上内存
inputCpuPtrS[i] = (void *)malloc(inputSizeS[i]); //分配CPU上的内存
//printf("%d\n", inputSizeS[i]);
//获取输入的维度信息 NHWC
CNRT_CHECK(cnrtGetInputDataShape(&dimValues,&dimNum,i,function));
printf("input shape:\n");
for(int y=0;y<dimNum;y++)
printf("%d ",dimValues[y]);
printf("\n");
input_width=dimValues[2];//640
input_height=dimValues[1];//384
batch_size=dimValues[0];
free(dimValues);
//为输出节点 分配CPU/MLU内存
for (int i = 0; i < outputNum; i++) {
CNRT_CHECK(cnrtMalloc(&outputMluPtrS[i],outputSizeS[i])); //分配MLU上内存
outputCpuPtrS[i] = (void *)malloc(outputSizeS[i]); //分配CPU上的内存
//printf("%d\n", outputSizeS[i]);
//获取输出的维度信息 NHWC
CNRT_CHECK(cnrtGetOutputDataShape(&dimValues,&dimNum,i,function));
int count=1;
printf("output shape:\n");
count=count*dimValues[y];
printf("\n");
outputCpuNchwPtrS[i] = (void *)malloc(count*sizeof(float)); //将输出转为float32类型,方便用户后处理
output_count.push_back(count);
free(dimValues);
//配置MLU输入/输出 地址的指针
param = (void **)malloc(sizeof(void *) * (inputNum + outputNum));
for (int i = 0; i < inputNum; i++) {
param[i] = inputMluPtrS[i];
param[i + inputNum] = outputMluPtrS[i];
//设置输入/输出的节点 索引
int input_idx=0;
// int output_idx=0;
printf("batchsize:%d\n",batch_size);
vector<cv::Mat> imgs;
vector<string> img_names;
unsigned char *ptr=(unsigned char *)inputCpuPtrS[input_idx];
for(int i=0;i<batch_size;i++)
// 选项 2 是yolov5的数据预处理方式
img_names.push_back(image_path);
cv::Mat input_image=cv::imread(image_path);
printf("input_image.shape:%d %d\n",input_image.rows,input_image.cols);
imgs.push_back(input_image);
cv::Mat input_image_resized;
cv::resize(input_image,input_image_resized,cv::Size(input_width,input_height));
if(is_rgb==1)
cv::Mat net_input_data_rgba(input_height,input_width,CV_8UC4,ptr);
cv::cvtColor(input_image_resized, net_input_data_rgba, CV_BGR2RGBA);
ptr+=(input_height*input_width*4);
} else if(is_rgb==0) {
cv::cvtColor(input_image_resized, net_input_data_rgba, CV_BGR2BGRA);
} else if(is_rgb==2) {
cv::Mat sample_temp;
int img_w = input_image.cols;
int img_h = input_image.rows;
cv::Mat sample_temp_bgr(input_image.cols, input_image.rows, CV_32FC3);
printf("entering yolov5 preprocess\n");
float img_scale = img_w < img_h ? (input_height / img_h) : (input_width*1.0 / img_w);
printf("input_height:%d\tinput_width:%d\timg_h:%d\timg_w:%d\timg_scale:%f\n",input_height,input_width,img_h,img_w,img_scale);
int new_w = std::floor(img_w * img_scale);
int new_h = std::floor(img_h * img_scale);
cv::cvtColor(input_image, sample_temp_bgr, CV_BGR2RGB);
cv::resize(sample_temp_bgr, sample_temp, cv::Size(new_w, new_h), CV_INTER_LINEAR);
cv::Mat net_input_data_rgba(input_height,input_width,CV_32FC3,ptr);
printf("input_height:%d\tinput_width:%d\tnew_h:%d\tnew_w:%d\n",input_height,input_width,new_h,new_w);
//384 640 360 640
sample_temp.copyTo(net_input_data_rgba(
cv::Range((static_cast<float>(input_height) - new_h) / 2,//12
(static_cast<float>(input_height) - new_h) / 2 + new_h),//372
cv::Range((static_cast<float>(input_width) - new_w) / 2,//0
(static_cast<float>(input_width) - new_w) / 2 + new_w)));//640
net_input_data_rgba /= 255.0;
cout<<net_input_data_rgba.size()<<endl;//640*384
cout<<"-----start to copy data to device------"<<endl;
auto t0=GetTickCount();
//拷贝输入数据到MLU内存
CNRT_CHECK(cnrtMemcpy(inputMluPtrS[input_idx],inputCpuPtrS[input_idx],inputSizeS[input_idx],CNRT_MEM_TRANS_DIR_HOST2DEV));
cout<<"input_idx:"<<input_idx<<endl;
cout<<"-----start to set notifier------"<<endl;
//创建事件
cnrtNotifier_t notifier_start; //用来记录硬件时间
cnrtNotifier_t notifier_end;
CNRT_CHECK(cnrtRuntimeContextCreateNotifier(ctx,¬ifier_start));
CNRT_CHECK(cnrtRuntimeContextCreateNotifier(ctx,¬ifier_end));
CNRT_CHECK(cnrtPlaceNotifier(notifier_start, queue));
cout<<"-----start to set parameters------"<<endl;
//设置invoke的参数
unsigned int affinity=1<<dev_channel; //设置通道亲和性,使用指定的MLU cluster做推理
cnrtInvokeParam_t invokeParam; //invoke参数
invokeParam.invoke_param_type=CNRT_INVOKE_PARAM_TYPE_0;
invokeParam.cluster_affinity.affinity=&affinity;
//执行算子
cout<<"-----start to process------"<<endl;
CNRT_CHECK(cnrtInvokeRuntimeContext_V2(ctx,nullptr,param,queue,&invokeParam));
cout<<"-----process completed------"<<endl;热门帖子
