CNStream demo---图像去雾 wenxiaoya2019-09-29 11:02:24 回复 11 查看 视频流处理SDK CNStream
1.下载源代码
github地址:https://github.com/Cambricon/CNStream
2.进入到目录
cd /cnstream/samples/detection-demo
3.在后处理postprocess中增加去雾后处理的Dehazepost.cpp
定义自己的类PostprocDehaze继承父类Postproc,并且实现父类的虚函数Execute。(完整代码如下)
int PostprocDehaze::Execute(const std::vector& net_outputs,
                    const std::shared_ptr& model,
                    const CN InfoPtr& package)
#include "postproc.hpp"
#include #include #include #include #include #include #include #include #include #include #include "cnbase/cntypes.h"
namespace cnstream {
using std::string;
using std::vector;
using namespace cv;
class PostprocDehaze : public Postproc, virtual public libstream::ReflexObjectEx {
public:
   int Execute(const std::vector& net_outputs,
               const CNFrameInfoPtr& package);
private:
   void  Process(std::shared_ptr data, Mat mat);
   double Acount(cv::Mat dark, cv::Mat img);
   Mat  Guidedfilter(cv::Mat gray,cv::Mat mat);
   DECLARE_REFLEX_OBJECT_EX(PostprocDehaze, Postproc);
 };  // class PostprocDehaze
 Mat PostprocDehaze::Guidedfilter(cv::Mat img,cv::Mat mat){
    Mat gray;
    int height = img.rows;
    int width = img.cols;
    cvtColor(img,gray,CV_BGR2GRAY);
    gray.convertTo(gray,CV_32FC1);
    for (int i = 0; i<height; i++)
      for (int j = 0; j<width; j++)
          gray.at(i, j)=gray.at(i, j)/255.0;
    int r = 60;
    double eps = 0.0001;
    Mat mean_I;
    mean_I.convertTo(mean_I,CV_32FC1);
    boxFilter(gray,mean_I,-1,Size(r,r),Point(-1,-1),true,BORDER_DEFAULT);//方框滤波器来模糊一张图片
    Mat mean_p ;
    mean_p.convertTo(mean_p,CV_32FC1);
    boxFilter(mat,mean_p,-1,Size(r,r),Point(-1,-1),true,BORDER_DEFAULT);
    Mat mean_Ip;
    mean_Ip.convertTo(mean_Ip,CV_32FC1);
    Mat GM;
    GM.convertTo(GM,CV_32FC1);
    GM=gray.mul(mat);
    boxFilter(GM,mean_Ip,-1,Size(r,r),Point(-1,-1),true,BORDER_DEFAULT);
    Mat cov_Ip;
    cov_Ip.convertTo(cov_Ip,CV_32FC1);
    Mat MM;
    MM.convertTo(MM,CV_32FC1);
    MM=mean_I.mul(mean_p);
    cov_Ip = mean_Ip - MM;
    Mat mean_II;
    mean_II.convertTo(mean_II,CV_32FC1);
    Mat GG;
    GG.convertTo(GG,CV_32FC1);
    GG=gray.mul(gray);
    boxFilter(GG,mean_II,-1,Size(r,r),Point(-1,-1),true,BORDER_DEFAULT);
    Mat var_I;
    var_I.convertTo(var_I,CV_32FC1);
    Mat II;
    II.convertTo(II,CV_32FC1);
    II=mean_I.mul(mean_I);
    var_I = mean_II - II;
    Mat a;
    a.convertTo(a,CV_32FC1);
    a = cov_Ip/(var_I + eps);
    Mat b;
    b.convertTo(b,CV_32FC1);
    Mat AM;
    AM.convertTo(AM,CV_32FC1);
    AM=a.mul(mean_I);
    b = mean_p - AM;
    Mat mean_a ;
    mean_a.convertTo(mean_a,CV_32FC1);
    boxFilter(a,mean_a,-1,Size(r,r),Point(-1,-1),true,BORDER_DEFAULT);
    Mat mean_b ;
    mean_b.convertTo(mean_b,CV_32FC1);
    boxFilter(b,mean_b,-1,Size(r,r),Point(-1,-1),true,BORDER_DEFAULT);
    Mat q;
    q.convertTo(q,CV_32FC1);
    Mat MG;
    MG.convertTo(MG,CV_32FC1);
    MG=mean_a.mul(gray);
    q = MG + mean_b;
    q=cv::max(q,0.1);    return q;
    double PostprocDehaze::Acount(cv::Mat dark, cv::Mat img){
    double sum=0;       //像素点符合条件A的和
    int pointNum = 0;   //满足要求的像素点数
    double A = 0;       //大气光强A
    double pix =0;      //暗通道图中照亮度的前0.1%范围的像素值
    CvScalar pixel;     //按图中符合A的点,在雾图中对应的像素
    float stretch_p[256], stretch_p1[256], stretch_num[256];
     //清空三个数组,初始化填充数组元素为0
    memset(stretch_p, 0, sizeof(stretch_p));
    memset(stretch_p1, 0, sizeof(stretch_p1));
    memset(stretch_num, 0, sizeof(stretch_num));
    IplImage tmp = IplImage(dark);
    CvArr* arr = (CvArr*)&tmp;
    IplImage tmp1 = IplImage(img);
    CvArr* arr1 = (CvArr*)&tmp1;    for (int i = 0; i<height; i++)
        double  pixel0 = cvGetReal2D(arr, i, j);
        int   pixel = (int)pixel0;
        stretch_num[pixel]++;
    }    //统计各个灰度级出现的概率
    for (int i = 0; i<256; i++)
      stretch_p[i] = stretch_num[i] / (height*width);
    }    //统计各个灰度级的概率,从暗通道图中按照亮度的大小取前0.1%的像素,pix为分界点
      for (int j = 0; j 0.999)
          pix = (double)i;
          i = 256;
          break;
    for (int i = 0; i< height; i++)
      for (int j = 0; j  pix )
          pixel = cvGet2D(arr1, i, j);
          pointNum++;
          sum += pixel.val[0];
          sum += pixel.val[1];
          sum += pixel.val[2];
    A = sum / (3 * pointNum);
    A = A/255.0;    if (A > 220.0)
      A = 220.0;
     printf("float: %f\n", A);
     return A;
                             const CNFrameInfoPtr& package) {
     if (net_outputs.size() != 1) {
         std::cerr <output_shapes()[0];
    auto data = net_outputs[0];
    int height = sp.h();
    int width = sp.w();
    Mat mat = Mat(height,width,CV_32FC1, data);//网络输出透射图
    std::cout<<"mat height::"<<height<<width<<std::endl;
    Process(package,mat);
    return 0;
  void  PostprocDehaze::Process(std::shared_ptr data, Mat mat) {
  int width = mat.cols;
  int height = mat.rows;
  std::cout<<"data height::"<<height<<width<frame.ImageBGR();
  Mat q, Dehaze;
  double A = 0.0;//大气光值
  imwrite("img.jpg",img); //得到原图
  cv::resize(img, img, Size(width,height));//将原图大小调整为和网络输出大小相同
  vector rgb;
  split(img,rgb);
  Mat dc=cv::min(cv::min( rgb.at(0),rgb.at(1)),rgb.at(2));//暗通道实际上是在rgb三个通道中取最小值组成灰度图
  Mat kernel = getStructuringElement(cv::MORPH_RECT,Size(15,15));
  Mat dark;
  erode(dc,dark,kernel);//腐蚀就是最小值滤波
  A = Acount(dark,img);//1.从暗通道图中按照亮度大小取前0.1%的像素。2.在这些位置中,在原始图像中寻找对应具有最高亮度点的值,作为A值。
  q = Guidedfilter(img,mat);//引导滤波
  Dehaze = Mat(height,width,CV_32FC3);
  img.convertTo(img,CV_32FC3);  //将得到的原图进行归一化以便后续计算
  {  for (int j = 0; j<width; j++)
        img.at(i, j)[0]=img.at(i, j)[0]/255.0;
        img.at(i, j)[1]=img.at(i, j)[1]/255.0;
        img.at(i, j)[2]=img.at(i, j)[2]/255.0;
       Dehaze.at(i, j)[0]=(((img.at(i, j)[0]-A)/q.at(i, j))+ A)*255;
       Dehaze.at(i, j)[1]=(((img.at(i, j)[1]-A)/q.at(i, j))+ A)*255;
       Dehaze.at(i, j)[2]=(((img.at(i, j)[2]-A)/q.at(i, j))+ A)*255;
  static int i = 0;
  std::string img_name = std::to_string(i++) + ".jpg";
  imwrite(img_name, Dehaze);
  IMPLEMENT_REFLEX_OBJECT_EX(PostprocDehaze, Postproc)
}  // namespace
net_outputs中可以获取网络输出,package中可以得到原图,流程如下:
a
得到网络输出透射图t(x)
b
img = cv::Mat(data-> .height*3/2, data-> .width, CV_8UC1, img_data, data-> .strides[0]);
得到原图
c
d
1.从暗通道图中按照亮度大小取前0.1%的像素。 2.在这些位置中,在原始图像中寻找对应具有最高亮度点的值,作为A值。
引导滤波
e
根据投射图和原图以及大气光值恢复去雾后的图像
4.图片路径
我自己的图片存放在
/detection-demo/test_dehaze/images
需要写一个files.list_image指明图片路径
5.改写配置文件dehaze_config.json
(a)next_modules:dehaze
(b)model_path:指明模型路径
(c)postproc_name:指明子类类名
6.运行脚本
图片路径我们将以参数形式传入,当我们输入为图片时要将input_image改为true,同理,若输入为视频则将其改为false
7.编译运行
在目录/cnstream/build下进行
camke ..
make -j8
运行
./run_dehaze.sh files.list_image
8.运行结果
我们以imwrite的形式将图片保存下来,视频也是一帧帧保存为图片,后续会再进行改写
