解码时pfnCncodecEventCallback没有响应 已解决 shilei2022-10-27 18:46:02 回复 5 查看 技术答疑 使用求助
先上代码
//根据FFMPEG的AVStream生成cnvideoDecCreateInfo
bool BuildDecInfo(AVStream* _stream, cnvideoDecCreateInfo& _info)
    memset(&_info, 0, sizeof(_info));
    cncodecType codec_;
    switch (_stream->codecpar->codec_id)
    case AV_CODEC_ID_H264:
        codec_ = CNCODEC_H264;
        break;
    case AV_CODEC_ID_HEVC:
        codec_ = CNCODEC_HEVC;
        break;
    case AV_CODEC_ID_VP8:
        codec_ = CNCODEC_VP8;
        break;
    case AV_CODEC_ID_VP9:
        codec_ = CNCODEC_VP9;
        break;
    default:
        return false;
    _info.codec = codec_;
    _info.userContext = this;
    _info.pixelFmt = CNCODEC_PIX_FMT_NV12;
    _info.instance = CNVIDEODEC_INSTANCE_AUTO;
    _info.allocType = CNCODEC_BUF_ALLOC_LIB;
    _info.height = _stream->codecpar->height;
    _info.width = _stream->codecpar->width;
    _info.bitDepthMinus8 = 0;
    _info.suggestedLibAllocBitStrmBufSize = 0;
    _info.inputBufNum = 8;
    _info.inputBuf = nullptr;
    _info.outputBufNum = 8;
    _info.outputBuf = nullptr;
    _info.progressive = 1;
    _info.deviceId = 0;
    return true;
//创建
if (cnvideoDecCreate(&handle, DecodeCallback,
    &dec_info) != 0)
    return false;
//回调函数
int DecodeCallback(cncodecCbEventType _type,
    void* _instance, void* _data)
    auto decoder_ = (Decoder*)_instance;
    switch (_type)
    case CNCODEC_CB_EVENT_NEW_ :
        decoder_->Enqueue((cnvideoDecOutput*)_data);
        break;
    case CNCODEC_CB_EVENT_SEQUENCE:
        decoder_->seq_info =
            *(cnvideoDecSequenceInfo*)_data;
        cnvideoDecStart(decoder_->handle,
            &decoder_->dec_info);
        break;
    default:
        break;
    return 0;
//解码
int Decode(AVPacket* _packet)
    cnvideoDecInput input_ = {};
    input_.streamBuf = _packet->data;
    input_.streamLength = _packet->size;
    input_.flags |= CNVIDEODEC_FLAG_END_OF_ ;
    if (_packet->size == 0)
        return 0;
    auto ret_ = cnvideoDecFeedData(handle, &input_, 10000);
    if (ret_ == -CNCODEC_TIMEOUT)
        cnvideoDecAbort(handle);
        return -1;
    else if (ret_ < 0)
        return -1;
    return 1;
都是AV_CODEC_ID_H264,
使用这个测试地址可以正常解码:
rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mp4
使用这个测试地址回调函数一直没有被执行:
rtmp://ns8.indexforce.com/home/mystream
请教各位,这是什么原因?
